Sponsored by: Real Truck
05-07 iPhone 6+ mod question
Old Sep 20, 2014 | 05:02 PM
kengarchow's Avatar
kengarchow
I keep my phone in the pocket next to the oem brake controller in my 06 S
Now with the I phone 6 + I need a little more width so want to see if I can heat and stretch the back of the pocket
Can someone tell me how to get this out please
Thanks
Old Sep 20, 2014 | 05:07 PM
NorEasterMA's Avatar
NorEasterMA
Pry it out. Get a small flathead or panel removal tool under the top and bottom edges and work it outwards. There may be a harness plug attached to the back of the pocket, which would be for up fitters switches if not equipped. Otherwise it'll come right out, and it'll snap right back in when you've stretched it.
Old Sep 20, 2014 | 08:10 PM
kengarchow's Avatar
kengarchow
thanks must be in there pretty tight
Old Sep 20, 2014 | 08:18 PM
NorEasterMA
There are two clips on the top and a lip on the bottom, if I remember correctly. I had it in and out several times in my '06 when I was taking measurements to install a second set of upfitters. I ended up being able to pop one side out, and then loosen the other top clip and just yank the whole thing forward. I learned to not be afraid, and once I stopped trying to be overly gentle it was a whole lot easier…keep in mind it's just a piece of plastic it's going to really take a whole lot to break it.
Old Sep 21, 2014 | 06:58 PM
kengarchow's Avatar
kengarchow
Got er done
Pocket came out with a good tug
Please note the brake controller has to come partially out to do a lip on the pocket
Behind the controller
Heat gun and a towel around phone worked to stretch it enough for a good fit
shellshock
Jul 23, 2012 08:38 AM
Wizard1946
Apr 2, 2008 08:26 PM
DanielN
Dec 21, 2006 08:23 AM
superdutywannab
Modular V8 (4.6L, 5.4L)
Mar 21, 2006 10:40 AM
