Battery cable fix?
Old Sep 20, 2014 | 04:33 PM
Restlesswildman's Avatar
Restlesswildman
Battery cable fix?
Since I am a cheap A$$....and I have a cracked/broken battery terminal on the passenger side.....
I was wondering if anyone has had the same issue and come up w a fix.
I really do not want to spend the $ on a complete assembly.
Old Sep 20, 2014 | 04:38 PM
cheezit's Avatar
cheezit
Go to an alternator shop and have someone there put a new end on it, or buy the correct tool and diy.
Old Sep 20, 2014 | 06:05 PM
Restlesswildman
It is the terminal that the starter cable makes a 90 degree bend up and over the battery.
Old Sep 20, 2014 | 08:58 PM
mhoefer's Avatar
mhoefer
Probably the cheapest thing to do is get a two terminal battery clamp and ends to crimp on the wires. I am assuming this is the positive cable on the passenger battery? This will require two ends to crimp and a crimping tool, but you have to pull the cables out to crimp them.
Old Sep 20, 2014 | 11:26 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
First off,, have you priced the battery cable?? It's surprisingly inexpensive. I keep one on the shelf. It's less than 100. And it's driver side, to pass side, to remote start wire, to starter,,, with all the looms and push pins on it.
Old Sep 21, 2014 | 02:01 PM
Restlesswildman
Not yet! I am fighting an injector issue at the moment!!
I am officially at my limit with this truck and life atm! To much going on and not enough time.
Old Sep 21, 2014 | 09:26 PM
jswartz84's Avatar
jswartz84
I'd just stop by the parts store and pick up a new end. They make the metal style clamp that goes over the battery terminal. There is also a crimp on connector that will bolt to the new terminal clamp in the package and I believe it's about $6.
fmc400
23
Jun 27, 2020 02:56 AM
handyandy123
Aug 27, 2010 04:44 PM
WALFORD'S 56
13
Jul 22, 2010 11:20 AM
y0manda
Nov 10, 2007 05:21 PM
