a/c
Old Sep 19, 2014 | 09:29 PM
deepswag1889's Avatar
deepswag1889
a/c
I got 92 fordranger 2.3 5 speed I got cold a/c but win I turn it on truck over heat win turn on heat it dont win every is off it dont just win the ac is on plz let me u got any ideas
Old Sep 20, 2014 | 12:03 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
As I take it, when you turn the AC on, it works ok, but the engine overheats????? If so, look to a problem with the fan clutch or maybe its fluid has leaked out. The fan blades should move, but with some resistance, it should Not free wheel/spin with no resistance.
What kind of shape is the coolant & cooling system in??? When last was the thermostat & radiator cap, serp belt & maybe the belt tensioner & water pump replaced, the cooling system flushed & the condenser & radiator fins inspected for obstruction, or cleaned???? Have you checked the belt tensioner range marks, to see if belt tension is in spec???? Some thoughts for consideration, let us know what you find.
Crick07
Feb 1, 2010 10:46 AM
Thudpucker
1997 - 2003 F150
Jan 18, 2010 05:54 PM
ColeinDesoto
Mar 17, 2009 06:44 PM
nflfreak43
Oct 7, 2008 07:08 PM
Golfmore
Aug 20, 2004 10:51 PM
