Sponsored by: Auxito
actuator
Old Sep 18, 2014 | 07:37 PM
tommcdonald's Avatar
tommcdonald
actuator
help, new to this. don't know what a thread is. just wanted to find out how to replace power door actuator on a 2000 f150.
Old Sep 18, 2014 | 08:45 PM
steve(ill)'s Avatar
steve(ill)
tom, for specific details, you need to say if your replacing the door switch panel, the inside door lock motor, or the window motor.
Old Sep 25, 2014 | 06:56 PM
tommcdonald
power doorlock acuator
I have received a new power door lock acuator for my 2000 f-150, drivers side. I'm looking for info on the installation. Thanks.
Old Sep 25, 2014 | 08:32 PM
Bluegrass 7's Avatar
Bluegrass 7
Take a good look at actuator, in your hand.
Does it suggest how it's mounted?
Remove the door panel, the paper cover and anything that is in the way.
inside the panel between the inner and out door panels is where the actuator is mounted.
Remove the mounting hardware, remove the power connector, remove the old actuator by unhooking the rod to door lock assembly.
Reverse the whole removal job to reinstall.
Test out before putting door panel back on.
Some of it is not so easy to do.
Good luck.
97ExplorerEddieBauer
Oct 6, 2004 12:55 AM
Hart 2000 EB AWD
Sep 16, 2004 03:24 PM
mrmootsie
Mar 21, 2004 07:43 AM
firstford
Oct 20, 2003 09:33 PM
ARTURO TOSCANO
Jul 22, 2003 04:39 PM
