I would throw a couple hundred on a y pipe. How many miles on it? There should be no labor, just the part. Maybe they'd let you ship it to Josh and have the bellows done.
Glow plugs n wires
If its an 04,, I've got pics on here somewhere of a hpop cover I grinded to give the discharge tube more clearance. Doesn't take much.
I called the local stealership here to get a quote and they told me $3300 for studs,gaskets,dummy plugs, standpipes, STC HPOP fittings, and I have everything this was just for the labor
Two shops I had quote me for the same(studs, gaskets, head work, oil cooler, EGR delete) were between 1200-1800 for labor if I supplied parts. 2700-3200 for labor and parts.
When I looked it up in all data just for head gaskets im pretty sure the labor was 20HRS just for the head gaskets, but they shouldn't be charging you much more for the STC fitting as the dummy plugs and blue spring are pretty much right there!!
