cold white smoke
Old Sep 18, 2014 | 04:15 PM
brokeasajoke's Avatar
brokeasajoke
cold white smoke
Ok i know this has been discussed quite a bit. My 88 blows alot of white smoke at start up and for about a mile. After a little heat builds it quits. Does seem to miss cold. Measuring gps and cracking lines seem to be the only way to diagnose. Pump is very fresh less than 1k miles but the injectors have about 3-4k. They are pensecola remans $159 a set. Dirty injector or bad. Dont mind replacing it if i find it. Was about a month after i put new ip on. Maybe got some trash in lines?
Last edited by brokeasajoke; Sep 18, 2014 at 04:16 PM. Reason: fix errors cause my fingers are fat
Old Sep 18, 2014 | 04:38 PM
sjwelds's Avatar
sjwelds
Uh well all I can say is I've heard way more bad than good about pensacola injectors ...
Old Sep 18, 2014 | 04:54 PM
bashby's Avatar
bashby
Maybe a bad glow plug or 3??
Old Sep 18, 2014 | 09:23 PM
Macrobb's Avatar
Macrobb
Might be both bad glow plugs and crummy injectors. Knowing what I do now, I'd not buy any 'remanufactured' injectors -- they're all just cleaned and matched. No parts are replaced.
I've had a couple of them flake out, or become leaky.
Having recently gotten a set of new Delphi injectors -- even at $350 -- it's a much better deal. They are nice and tight, pop consistantly and don't leak down over night. (I had one that ended up slowly leaking half the fluid in the line out, so it would run on 7 for the first minute or two(less if I revved it) until it pressurized the line again.
Old Sep 18, 2014 | 10:17 PM
brokeasajoke
Humm. It starts so easy since i put racins pump on, a gp never crossed my mind. I just have to look at the key and it will start.lol I will have to check that next chance i get.
Old Sep 19, 2014 | 01:45 PM
brokeasajoke
Had to pull a skidsteer today didnt check gps. Had to start and go no warm up. Heard injector knocking today while cold.
Old Sep 19, 2014 | 03:11 PM
RacinNdrummin's Avatar
RacinNdrummin
Not all of them are just cleaned and matched, there is other processes that go into them as well. You are correct in saying that no hard parts are replaced, but its not correct to assume nothing is done to the hard parts to make them function like a new set... It is possible.
That being said, I cant comment on the work that goes into Pensacola injectors.
Old Sep 19, 2014 | 03:15 PM
RacinNdrummin
If the injectors were just cleaned and put back together, they could have a couple with hanging pintles if it runs rough. Most likely the rough running is from unmatched pop pressures, and white smoke is common on any IDI when its cold, especially if the timing is slightly retarded.
Is your cold advance hooked up and working?
Most of the time its a scored pintle bore that causes injector to act up and squirt funny.
Old Sep 19, 2014 | 03:55 PM
brokeasajoke
No cold advance is not hooked up. Dosent run rough after a half mile or so. Im thinking injector since it is all of a sudden. I also seem to be losing coolant. None in oil. Not overheating at all either.
Old Sep 19, 2014 | 04:05 PM
RacinNdrummin
Try hooking the cold advance up and see if it does anything for the smoke, That is its primary function besides warming the truck up faster.
Old Sep 19, 2014 | 04:17 PM
brokeasajoke
What does the sensor look like and where is it. Not sure mine has it. The wire is there for it at ip
lalh20
Nov 24, 2012 07:57 AM
pitless
Jul 25, 2010 10:03 PM
bcarless
Nov 29, 2009 10:12 PM
usmc50bmgsniper92
13
Aug 19, 2008 09:57 PM
