Front end wobble
Old Sep 18, 2014 | 05:40 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Front end wobble
I have a 05 F250 with a fab tech lift runnin 37x13.5x18 tires. It has dual steering stabilizer kit on it. I just replaced the drag link an the tie rod end that goes from the steering box to the right side tire. It has a bad front end wobble under braking. You can look out the window an see the front tires wobble. All the other front end components look good. Just wondering if someone else has had this same problem an what they did to fix it. ?
Old Sep 18, 2014 | 06:21 AM
WatsonR's Avatar
WatsonR
Checked your wheel bearings? I'd also check the ball joints. Seems these trucks go thru wheels bearing about every 100,000 from what I'm told. Mine went 110K left side 118k right side. That lift doesn't help with added stress to those parts.
Old Sep 18, 2014 | 07:20 AM
05 f250 6 inch lift
Thanks. I will check/replace them an I hope that will fix it. Truck has bout 170K miles on it.
Old Sep 18, 2014 | 08:03 AM
cheezit's Avatar
cheezit
Check rotor run out. Warped rotors is a good possibility
Old Sep 18, 2014 | 08:22 AM
05 f250 6 inch lift
Thanks cheezit. I didn't think warped rotors would make the front tires wobble this bad. But I guess its possible. I will check those too.
Old Sep 18, 2014 | 12:06 PM
kbf1961's Avatar
kbf1961
I had a bad wobble at hi speed braking +40mph. Replaced the rotors solved the problem
Old Sep 18, 2014 | 06:56 PM
05 f250 6 inch lift
Thanks man. Exactly the problem I'm having. I got new rotors an pads on the way. They will b here in the mornin.
I thank y'all for all the help. Everyone on this site are the BEST !!!!!
Old Sep 18, 2014 | 07:31 PM
22fordguy's Avatar
22fordguy
Well I know whats causing mine now. Thanks guys Guess it will be added to the list.
Old Sep 19, 2014 | 08:30 PM
05 f250 6 inch lift
Update.
I got new rotors an pads on front.
NO MORE TIRE WOBBLE WHILE BRAKING !!!!!
THANKS for all the help y'all. !!!!!!!!!
kbf1961
Oct 7, 2014 04:09 PM
bakerbuilttracks
Apr 6, 2013 09:24 PM
acw592
2004 - 2008 F150
19
Aug 2, 2011 07:19 AM
oobical
22
Jan 3, 2011 09:30 PM
kdfishe43
Apr 26, 2010 06:43 PM
