Installing head studs this weekend-Finished!!
The old arp lube called for 250 ft lbs. That lube wouldn't allow the torque to be consistent,, thus the higher torque value. The "ultra torque" lube arp has out now has iirc a 95% likely hood of hitting the value on the first sequence. I do final torque to 215 with ultra torque. I also lube the studs first,, then both sides of the washer while installing,, then the base of the nut n the threads just before threading them on. You will know if you did not lube enough if they "pop" while tightening. No pops here,,, EVER.
I have read threads where people do gaskets+studs and they still blow again in 10K miles-I guess doing anything to these trucks is a "gamble" Not trying to argue with you, but I have read countless success stories both with just doing 1 stud at a time and doing studs and gaskets....
I am willing to give it a shot.
As far as the turbo feed and drain tube, there are updates to both you should consider. Trucks built after January 2006 came from the factory with the updated turbo feed and drain tubes from what I remember.
Me as well as many other know it's not the "right" way but with good gaskets and the POS TTY bolts that fail on A LOT of 6.0s I wanted to do it now and not worry, and if they do good bad, heck what am I out-just my time the studs are re useable.
Anyways, I did the studs tonight. Took me 7 hours start to finish. I started @ 6:00PM And the truck was running by 1AM .... I did the driver side first that side SUCKED. Not a lot of room and that back bolt by the fire wall wasn't easy either I ended up denting the fire wall AND cutting the bolt to get it out. Then to slide the stud in with out hitting the fire wall again I took off the trans mount bolts and jacked it up there which tilted the motor forward and the stud slid in.
I did it in reverse factory torque sequence I did a lot of reading about this subject and it seems that's the going method for doing it.
The pass side was a PIECE OF CAKE! I removed the HVAC box after removing the refrigerant @ my shop and I had so much room in there it was unreal.
I went to 165LBS after removing the factory bolt and installed the ARP I used plenty of lube and they all torqued very smoothly.
Then when all the ARP bolts were i went to 210LBS-ouch!
Got the truck all back together fired up after a couple seconds of cranking(normal) then I got a P0261 code and went back and looked at the harness and it wasn't fully seated. Good to go for now. Any questions just ask.
If I were to do head studs again I would pull the cab not for any other reason of I'd like to know how to do that.
Well I guess Friday night is part of the weekend... lol. Good job man, please post back from time to time with results good or bad. I do have some questions...
In the 7 hours, are the studs the only thing you did, or did you take care of any of the other "weak points"?
Could denting the FW or cutting the bolt been avoided if you had jacked up the Tranny first?
Did you drain all the coolant from the block plugs before starting the work?
I drained all the coolant and then I sucked all the oil out of the bolt holes...put the studs in hand tight as well
