Sponsored by: Real Truck
wireing
Old Sep 16, 2014 | 05:15 PM
dumptruck denny's Avatar
dumptruck denny
wireing
hi everyone,haven't been on for a while.got a 2004 f250 sd with towing package lost my turn signals to trailer and now the truck checked the fuses and they seem to be good what else can i try. thanks denny
Old Sep 16, 2014 | 05:24 PM
speakerfritz's Avatar
speakerfritz
ground circuts
Old Sep 16, 2014 | 05:28 PM
dumptruck denny
where would i find that at .thanks
Old Sep 16, 2014 | 05:38 PM
dumptruck denny
is there a fuse box under the hood i did not see one
Old Sep 16, 2014 | 06:07 PM
V10man's Avatar
V10man
Double check the fuses. If they are oem they may look good but aren't.
Old Sep 16, 2014 | 07:41 PM
Redrkt's Avatar
Redrkt
Regardless of whether the fuses look good or not, replace them and if that was not the problem move on to the next step in line. Always start at the beginning and work your way to the end don't start in the middle and try and figure it out. Fuses are cheap.
Old Sep 17, 2014 | 09:59 AM
David7.3's Avatar
David7.3
The box is located on the drivers side inboard from the air filter box, The big fuses are usually the trailer tow ones, they power relays so you dont have to use such heavy ga. wire to the back.
ithaca1230
Mar 9, 2017 04:06 PM
joshc_guitar
2004 - 2008 F150
Jun 4, 2008 08:19 AM
BuCKxWiLD
All Things Towing
Jul 15, 2005 10:41 PM
BuCKxWiLD
Jul 12, 2005 07:00 PM
BuCKxWiLD
Electrical Systems/Wiring
Jul 7, 2005 02:14 PM
