About the only thing I have never replaced in my front suspension and pretty sure they are the originals. Truck has power steering, new wider brand name wheels (Cragar) and tires (BFG). I have some of that over assisted feeling at speed and it darts at times when hitting large bumps just right.
Everything else (rag joint, suspension components, power steering pump) is all new or rebuilt. The darting is worse with the new wider wheels & tires. Shocks are older, but the bounce tests checks out good. So thinking it is the radius arm bushings.
What is the level of difficulty to replace these for the do it yourselfer?
There not that bad to do, but you can look and see if there good or not. If there all rotted out or mushroomed they need to be replaced plus you would hear the clunking everytime you hit a bump, Im thinking axle pivot bushings, usually when you get that floating feeling you either have to much caster, that is what makes the steering wheel return after you make a turn. If it's off you get that over steer feeling or those bushings go bad and tilt the axle which effects caster.
hardest part would be to get the radius arm nut and driving out the through bolt on the i-beams. getting the spring out is not hard nor is reinstalling everything, I cant remember if the beam can be pulled far enough foreword to get bushing out. a impact would be your friend here but may want to check out king pins
The radius arm bushings are not bad. No special tools really. Getting them "squished" enough to get the big washer on was my biggest challenge. I purchased a minimal sized washer and a correct-sized nut and used that to squeeze them down and then installed the big "washer" and the nut that is supposed to be there.
Pivot arm - mine went to a repair shop for removal and installation of the bushings. Cost $25 per arm.
Well, just checked all 4 shocks. Rears are still firm, fromnts one is bad and the other is iffy. Time to replace those and see if that helps. When I replaced everything in the front 8 years or so ago, front seemed fine. Visually they still look good so I guess they just wore out. any brand recomendations for shocks?
I didn't replace those radius bushings when I was doing the front end as they looked good. I bought those parts and returned them. But I have not noticed any clunking.
I just put Monroe Gas Magnums on mine this week, and I am very happy with them. 34900 on the front and 34911 on the back. Is yours a 250? Those shocks would be a little stiff for a 100.
A couple of other guys on here have done shocks recently. Some Monroes, some KYB, and maybe some Ranchos - all seem happy with their choices. Good thing is you have choices, at least with the 250, as lots of other Ford trucks/vans used the same specs for the next 20+ years.
I just put Monroe Gas Magnums on mine this week, and I am very happy with them. 34900 on the front and 34911 on the back. Those shocks would be a little stiff for a 100.
That's what I just did. The rear shocks made a HUGE difference on the overall handling and ride. Much better. The fronts, not so much, maybe because my old front shocks were still ok. But they could be stiffer IMO. Even with the brand new magnums, the front end still bounces some. Maybe I'll make some brackets and use the old shocks as a second set on the front.
No swaybars front or back. Rear springs have the Ford heavy load shackle. Forget what Ford calls it.
Driving through my neighborhood, below 45 MPH it rides fine but does have some body lean, just figured it was due to no swaybars. I will go with a name brand, decent quality shock and see how it does before tackling the radius bushings. At some point I'd like to do a crown vic swap, but that is probably 1-2+ years down the road.
I have a F100 Shortbed. No swaybars front or back. Rear springs have the Ford heavy load shackle. Forget what Ford calls it. Driving through my neighborhood, below 45 MPH it rides fine but does have some body lean, just figured it was due to no swaybars. I will go with a name brand, decent quality shock and see how it does before tackling the radius bushings. At some point I'd like to do a crown vic swap, but that is probably 1-2+ years down the road.
Flex-o-matic is what ford called it.
Bad radius arm bushings will give a wandering/ bump steer reaction, particularly at higher speed.
Many of us have recently done shocks. In fact there is a current thread on the topic. Monroe gas magnum shocks are probably the most popular.
Installed some Gabriel shock, the regular duty, not "work truck" heavy duty. Made a big difference. Less sway around curves, less floaty feel. Need to find a big bump in the road and see if it still darts.
Also picked up some radius/control arm bushings, but have not yet installed them. As has been said, looks like that wil take some effort. I will save that for a rainy day.
