flareside wood bed replacement
Old Sep 20, 2014 | 10:59 PM
TxStang2010's Avatar
TxStang2010
I plan on using Red Cedar because of the beautiful colors since my truck will never sleep outside and probably won't see rain I think spar varnish will last forever
Old Sep 21, 2014 | 01:07 AM
TBird Larry's Avatar
TBird Larry
Spar varnish works great if it has the UV inhibitors. They recommend for boats that are outside all the time to re-coat with a fresh coat every year or two.
When I built my boat I used the west System Epoxy then applied 2 coats of Spar Varnish with the UV inhibitor and it looked like new all the time I had it. I kept it covered or parked inside.
Old Sep 21, 2014 | 10:23 PM
TxStang2010
Yes on the boat my dad had years ago we used Spar varnish on all the teak and it always looked great .
Old May 19, 2017 | 05:56 PM
Ttnc's Avatar
Ttnc
First, i do realize this is an old thread. For those who have gone to a new wood bed floor, how do you protect the floor if you need to haul something?
Old May 19, 2017 | 11:21 PM
RangerMercMan's Avatar
RangerMercMan
I will at some point be redoing my Flareside wood floor. I was wondering if you guys have a picture of this spacer mentioned here. I cannot read ND's schematic well and he mentioned it is correct only up to 1960.
Thanks RMM
Old May 20, 2017 | 09:45 AM
schoo's Avatar
schoo
One of the best ideas I read was a FTE guy said he went to a farm supply store and bought a cow stall mat they use for milking it was thick but tough and cut to size
Old May 20, 2017 | 11:48 AM
scottlathrop's Avatar
scottlathrop
I cut a 3/8 plywood down to fit the bed. It is light to handle, rides up off the wood on the chrome strips and is easy to remove and store in my garage.I did paint it so its protected from the salt water and looks good in the bed. I use a kayak often and haven't had a problem so far.
I had a horse/cow mat - but very heavy for continuous removal - but you could haul brick and block without damage
Old Jul 20, 2017 | 09:16 PM
oldracerjones's Avatar
oldracerjones
Is this bed wood dimension correct for a 1962 Flareside bed?
Originally Posted by ige1963
I'm doing the bed too. Ordered 48 board feet of red oak from a hardwood supplier. They didn't have the boards cut to 5 3/4 so I ended up paying for way more than I'll use. My son and I will do the work so no cost there. Planning to use stainless hardware and original (restored) battens. My wood bed had been covered by sheet metal by PO but all battens/slats were pretty rust free.
Still pondering finish. Any thoughts? I don't want to redo poly every other year.
This was an old post but looks like his bed wood dimension was 5 3/4 inch wide. Anyone know if this is correct?
My truck had no bed when I got it so I have no idea of the bed wood dimensions for a 6 1/2' bed.
Old Jul 20, 2017 | 11:47 PM
TxStang2010
Hope this helps
Old Jul 21, 2017 | 05:14 PM
oldracerjones
Thanks TXStang, just what I needed.
Old Jul 21, 2017 | 10:58 PM
thrifty's Avatar
thrifty
Oak wood with marine varnish. complete bed kit new, no bolts on the strips
Old Jun 3, 2019 | 08:19 PM
Srowe's Avatar
Srowe
Thank you for the info, can i inquire where you got this info from.
this is the inf i ghave been looking for in the forums for a few days
a source would be excellent if you still have it available.
Thank you
Scott
DGMFORD
Oct 16, 2013 04:54 PM
emeraldcoupe
Mar 19, 2010 04:39 PM
qtrmiler
Aug 19, 2002 08:12 PM
