Sponsored by: Real Truck
Scangauge 2 trans temp???
Old Jun 28, 2015 | 05:05 PM
MDSLIGHT's Avatar
MDSLIGHT
I have a 2003 F250 v10. I bought a scangauge 2 and hooked it up this morning. I cant get the transmission temp to work. I went to xgauge and entered the codes and the TFT comes up, however it reads a single digit number. It went from 5 to 7. I know my trans temp is not 7 degrees. Any advise would be great. Thanks
Old Jun 28, 2015 | 07:38 PM
Mike189677's Avatar
Mike189677
Transmission Fluid Temperature TXD C410F1221674 RXF 046205160674 RXD 3010 MTH 000100080000 NAME TFT Degrees Fahrenheit
This is the code you need to use if this is the one you used check to make sure you entered it correctly
Old Jun 28, 2015 | 07:44 PM
FordmanNJ's Avatar
FordmanNJ
Hi,
+1 to what the other guy said. The code he posted will probably be the winner since his truck is in the same age range. When I installed the SC2 in my F150, the TFT read without a problem. When the SC2 was moved from the F150 to the F250, I had 4 different codes to chose from. It turned out, it was the 3rd or 4th code that with the 6R140
Good luck.
Jun 7, 2017 11:24 AM
Emu83
Mar 7, 2017 09:43 PM
Quad Racer
Jun 18, 2015 07:20 PM
JIM_C
6.2L V8
Sep 23, 2014 08:31 PM
draboo
Nov 15, 2011 10:10 AM
