Exhaust Pipe
Old Sep 14, 2014 | 01:16 PM
genbryan's Avatar
genbryan
Exhaust Pipe
Has anyone ever had sound issues in the cab from changing out their stock down pipe to a 3" pipe? I did mine and it is 10 times louder in the cab it. Looks like I need to bend away some heat shielding from the pipe that's on the firewall. Also wondering if any additional in-cab sound deadening material under the carpet would help out with this, it seems to be that the sound is coming from one spot in the floor.
Old Sep 14, 2014 | 10:56 PM
oldbird1965's Avatar
oldbird1965
Sounds like your DP is rubbing on the firewall. Use a porta power and shove it away more.
If you want soundproofing, I did this:
https://www.ford-trucks.com/forums/1...dproofing.html
Old Sep 15, 2014 | 01:10 AM
genbryan's Avatar
genbryan
You're right it was. That's strange how such a small point of contact can resonate so much sound. I don't have a porta power but I shoved a large screw driver between the pipe and heat shielding and wallowed it around and voila, it worked, think I may not need to do much anymore for noise suppression. The cab mount kit sounds cool to that you talked about on your other thread, my cab sags a little to. That sound proofing job you did looks excellent to! That's gotta be really quiet in there now.
Old Sep 15, 2014 | 08:58 AM
oldbird1965
Sounds good but they tend to shift around a little so don't be surprised if you have to do something again. My wife is happy with the soundproofing, she was my motivation! LOL
TristanB
22
Dec 22, 2011 04:34 PM
Josh0525
Exhaust Systems
Apr 8, 2006 06:54 PM
turdbird
Jul 26, 2005 11:35 AM
big block power
Exhaust Systems
Nov 18, 2002 12:09 PM
