1966 4x4
Old Sep 14, 2014 | 08:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by TheV8tractor
So do you guys think I have the wrong f100 cab on a 66 f250 frame?
I would say so, since there's no cab step, no battery cover access plate.
See pic in post 11 for correct configuration.
If this is an F250, will have 8 lug wheels on a 6.50" bolt circle.
Old Sep 14, 2014 | 08:42 PM
TheV8tractor's Avatar
TheV8tractor
Heres the vin from the door
F10JK650746
Yes it has a hump at the rear axle
Old Sep 14, 2014 | 08:49 PM
TheV8tractor
Yes im sure its an f250, it has 8 lug wheels. Now the search begins for the right cab
Old Sep 14, 2014 | 08:50 PM
NumberDummy
Heres the VIN from the door: F10JK650746
Hmmm...
F10 = F100 2WD
J = 240 1V I-6.
K = Kansas City MO Assembly Plant.
650746 = 1965, assembled February 1965.
Compare this VIN on the Warranty Plate with the VIN on the registration/title to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time...they failed to install the original Warranty Plates on the replaced doors.
Not only is this Styleside bed incorrect for this cab, but it's mounted incorrectly.
IMO, this is a Frankenstein Monster, with parts swapped from gawd only knows what.
Old Sep 14, 2014 | 08:51 PM
schoo's Avatar
schoo
Ive been a long time lurker here but decided to join today. Ive got a 1966 4x4, I bought it to bring it back to its original configuration. I think the frame is a 1960 maybe?But id like to know for sure what year the frame is so I can find a cab. The cab on there is a 66 f100 and the box I think would be correct for the frame I think. It has a Dana 24 T case, 60 rear axle and maybe 44 front axle? It also has a battery box under the passenger side of the cab. Ill try and get some pics up if I can, but any help on the year of the frame would be appreciated. Thanks
F10JK650746
I would confirm that vin with the frame rt side top of rail near front shock
crazed87bronco's Avatar
crazed87bronco
The cab isn't a factory 4x4 cab it's been swapped at some point. And not positive but I think you have a f100 cab from the vin?
Old Sep 14, 2014 | 08:54 PM
crazed87bronco
Wow you guys replied a lot back and forth in the matter of minutes. Awesome ND decoded the vin just sad I was thinking f100 2WD
Old Sep 14, 2014 | 08:56 PM
schoo's Avatar
schoo
4wd F250frame are flat over rear axle no hump
Old Sep 14, 2014 | 09:05 PM
TheV8tractor
Can you please post a pic if you can of that spot of the frame if you have a 4wd f250
Old Sep 14, 2014 | 09:24 PM
1972RedNeck's Avatar
1972RedNeck
I would leave the cab. It has more leg room.
Old Sep 14, 2014 | 09:28 PM
crazed87bronco
Here's a pic showing the flat spot of my f100 4wd frame
Old Sep 14, 2014 | 09:29 PM
TheV8tractor
Hmmm...
F10 = F100 2WD
J = 240 1V I-6.
The title vin is F26DK716210. Got this truck from my dad, hopefully he has the other door
Old Sep 14, 2014 | 09:48 PM
  #28
crazed87bronco
The title vin matches a f250 4x4 352 2v somewhere down the line cab got messed with has it left ownership of your family ever?
Old Sep 14, 2014 | 09:53 PM
  #29
NumberDummy
F26 = F250 4WD
D = 352 2V
716210 = 1965, assembled July 1965.
So, what makes you think this is a 1966...is it registered as such? The grille is from a 1966.
  #30
schoo's Avatar
schoo
Ck the frame should be vin at rt side near shock and another near where the battery is on most 4wd slicks mid way under cab
A lot of things happening a fifty year old truck
