Power Steering Pump question
Old Sep 12, 2014 | 03:57 PM
gunner123's Avatar
gunner123
I have a 2001 F350 7.3 dually. The PS pump finally quit. Got it apart and started to put back together. In the bag were 2 o-rings. The teflon one is not a problem. The small black o-ring is a mystery to me. Does it go under the high pressure connection? Does that fitting slide out? I started to muscle it, but then thought better of it. Some direction would be appreciated.
Has anyone used the aftermarket filters, like the ones Cardone sells? This pump has two return lines, one is from the cooler, do both need a filter?
A boat load, but thanks for any help.
Gunner
Old Sep 12, 2014 | 04:15 PM
CGMKCM's Avatar
CGMKCM
I added a filter in the line from the hydra-boost return. Cant help mwith the other questions.
Old Sep 13, 2014 | 07:28 AM
Kamstutz's Avatar
Kamstutz
Springer Pop has a nice write up on a PS filter install. SpringerPop's Hydraulic Filter
Old Sep 13, 2014 | 08:04 AM
CGMKCM's Avatar
CGMKCM
Another option is cut hydra boost return line to PS pump, add filter shown below with a couple of hose clamps.
NAPA AUTO PARTS
Old Sep 13, 2014 | 08:35 AM
gunner123's Avatar
gunner123
Thanks guys. I'm going to add a filter in the return line. Sure would like to know where that little o-ring goes.
reamer
Dec 16, 2006 05:52 AM
Boltgunner
Mar 4, 2005 02:04 AM
Bookman
Jun 15, 2004 07:11 PM
dnakirks
Mar 31, 2004 08:52 PM
Motorcraftsman
May 11, 2000 07:45 AM
