Supercharged P/S pump
Old Jun 15, 2004 | 06:00 PM
Bookman's Avatar
Bookman
OK! So the kids barrowed the truck without permission or knowing it was disassembled so I took a chance and finished hookinh the hoses back up and added the Lucas P/S fluid which had helped the leaky seals. I thought it was dead but after filling it full it came back to life (BUT) when starting it cold the thing sounds like a supercharger for the first minute or so. What kind of life is left in it. I was going to replace it but it is working right now.
Old Jun 15, 2004 | 06:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
That is one of the good reasons for disconnecting the battery when you are working on a vehicle.
The pump is shot. Right now it is tearing the hell out of the rest of your system components. Replace it, flush the system, add a return line filter in the system, and keep your fingers crossed.
Wix transmission/PS filter #58964
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Ford equivalent filter kit #XC3Z-7B155-AA
filter alone #XC3P-7B155-BA
Old Jun 15, 2004 | 06:31 PM
Bookman's Avatar
Bookman
Thanks for the quick reply. Where does this filter go? I thought the return line is the one threaded into the back of the pump from the steering box. This unit also has a small radiator between the pump and the steering box.
Old Jun 15, 2004 | 07:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
The return line is your low pressure fluid return back to the pump. The rubber return line is cut and the filter is placed in the line much like a fuel filter. Since your system is full of trash from the pump get two filters (about $16 each) and replace the first filter after a week or so. It may save you a PS unit and another pump, and another pump...
