pulling while stopped
Old Sep 12, 2014 | 02:04 PM
Cj7clay's Avatar
Cj7clay
I have a 1978 f100 with a 302 c6 auto, completely stock, while sitting at a stop light the truck wants to go forward, if I let off of the brake the truck will go, I know it should do this a little but I really have to hold the brake to make sure it doesn't hit the car in front of me, what would be causing this?
Old Sep 12, 2014 | 02:29 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
What RPM in park are you idling at? Sounds like the carb is out of adjustment?
Old Sep 12, 2014 | 03:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, X2. Sounds like the idle speed is set too high.
Old Sep 12, 2014 | 04:15 PM
tanman722001's Avatar
tanman722001
X3 sounds like idle is to high
Old Sep 12, 2014 | 04:18 PM
Cj7clay's Avatar
Cj7clay
Thanks I will go and try to adjust carb
Old Sep 12, 2014 | 05:01 PM
redroad's Avatar
redroad
With an auto trans the idle speed is set with the truck in drive and the brake on .. So you need a trust worthy helper .. In your case though I would turn down the idle a little while in park before you start the in drive with brake on adjustment ..
Old Sep 12, 2014 | 05:36 PM
Cj7clay's Avatar
Cj7clay
Thanks, I will try that with my daughter behind the wheel
Old Sep 12, 2014 | 06:48 PM
dlburch's Avatar
dlburch
if your idle is ok, also consider that you could have a broken motor mount which would allow the motor to twist from the torque caused by being in gear...which could in turn put force on the throttle causing the engine to increase in rpm (thus causing more torque, etc...)
Old Sep 12, 2014 | 08:01 PM
Jdeshler's Avatar
Jdeshler
In my experience I have noticed a high idle purposely set to cover a stalling or a badly tuned Carb issue.. just spin down the idle (if possible) and see how she runs.. another issue I have seen in rebuilding my own carburetors is if the butterfly valves are not perfectly aligned they will not close and the motor will run just above idle..
Old Sep 13, 2014 | 08:49 AM
Cj7clay's Avatar
Cj7clay
Thanks, that want so hard to fix, some how the idle was high while in drive, dropped it down a little seems to be ok
Old Sep 13, 2014 | 08:58 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Glad it was something simple, thanks for the update.
Serapis
Sep 9, 2010 11:22 PM
DISLFVR
Feb 18, 2007 11:52 AM
nickmyron
1978 - 1996 Big Bronco
Jun 16, 2004 10:06 PM
CC
Feb 14, 2000 11:44 PM
