E4OD trans problem
Old Sep 12, 2014 | 01:50 PM
Nhull97's Avatar
Nhull97
E4OD trans problem
I have a 1996 f250 7.3L 4x4. I pulled the trans last week to replace the front seal. Put it all back together no problem. Changed trans oil and put a new pan gasket in it. Go to drive it last night and it won't move all the time in an gear. When it does move it doesn't take off until about 1500 rpm. Pan had some metal shavings in it. And the oil looked real nasty. Does anyone know what might be the problem. I want to make sure my trans isn't bad before I pull it again and get it rebuilt
Old Sep 12, 2014 | 02:00 PM
fordpride's Avatar
fordpride
Did you replace the filter ?
Old Sep 12, 2014 | 02:21 PM
Nhull97's Avatar
Nhull97
No I did not
Old Sep 12, 2014 | 03:48 PM
fordpride's Avatar
fordpride
Is the OD light flashing ?
Old Sep 12, 2014 | 04:15 PM
Nhull97's Avatar
Nhull97
It did for a few miles right before I pulled the trans
Old Sep 12, 2014 | 04:20 PM
fordpride's Avatar
fordpride
Then you have a stored code/s
Do you have a way to read codes ?
Old Sep 12, 2014 | 04:58 PM
Nhull97's Avatar
Nhull97
I've never done it before. Is there a special tool I need or is it one of those plugs I shove a paperclip in and the amount of flashes make up the code
Old Sep 12, 2014 | 05:22 PM
fordpride's Avatar
fordpride
You'll need a scan tool. The cheap/free ones at auto zone don't work.
Do you have a way to get it to a shop ?
Old Sep 12, 2014 | 07:19 PM
Nhull97's Avatar
Nhull97
I'm sure I could find a way.
Old Sep 14, 2014 | 08:13 PM
pilgrimbizket's Avatar
pilgrimbizket
Torque app on the android phones can pull your codes
mojoman
Aug 2, 2012 04:57 PM
8850dave
Jan 25, 2010 08:45 AM
kickstarter
16
Apr 28, 2007 06:26 PM
lt
Mar 12, 2001 05:52 PM
