E4OD trans problem
Old Jan 24, 2010 | 10:03 PM
8850dave's Avatar
8850dave
E4OD trans problem
I have 1994 F250HD with 460 and auto trans which just plows snow, the problem last year was in drive and overdrive it would work fine then all of a sudden act like it was in neutral, but 1st and 2nd would still work. Now this year forward gears work perfect and when put in reverse the trans acts like it is slipping. Truck has 59000 miles which direction should I go with this problem?
Old Jan 24, 2010 | 11:28 PM
Hitokori's Avatar
Hitokori
rebuilding it....
Old Jan 25, 2010 | 08:21 AM
rla2005's Avatar
rla2005
Another typical cause of no reverse is the trans. filter has dropped from it's mount. Drop the pan, inspect the filter. Also look for signs of metal. If the filter has dropped, consider replacing it as well as the fluid. If you see metal, time for a rebuild.
Old Jan 25, 2010 | 08:45 AM
lew52's Avatar
lew52
Yeah drop the pan & have a look....Lew
