Sponsored by: Auxito
air condition/heat blower
Old Sep 12, 2014 | 06:59 AM
l9_66's Avatar
l9_66
i have a 2001 f150 5.4 was driving in very hot weather on the Ms gulfcoast on sept 10,2014 with my ac on, i came to a light and stopped,and my ac fan stopped. i pulled to a safe place to see what caused it. i checked all fuses, they was all good, i checked my wireing, that was visable, they all checked ot okay.i have sinced checked relays in both(under hood),and on drivers side in cab, they all checked out good. i have since installed resisitor under dash on passenger side, still no fan. some one said there is another relay inside of truck, close to where the emrgency flasher relay is. i have pulled part of dash to find this relay, i have had no luck finding this.
anyone who could help me out with this, before i go buy a new blower and change something that may not need to be changed would be greatly appreciative. thanks, Patrick
Old Sep 12, 2014 | 07:30 AM
steve(ill)'s Avatar
steve(ill)
pull the plug on the resistor block and check for voltage at the power wire......... also check that the ground wire has continuity to the frame. Add a jumper from motor case to battery ground to verify.
troycoltscc
17
Aug 2, 2013 12:32 PM
77BlackBetty
Jan 27, 2009 05:57 PM
wattsup
Electrical Systems/Wiring
Oct 3, 2007 05:37 PM
ptrill
Nov 30, 2006 03:12 PM
JSpeed71
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 25, 2006 07:04 AM
