Same measurement points, this time while trying to start the truck.
This was in my previous instructions. A friend needs to be holding the key in START such that the engine would otherwise be cranking.
If that's what was done, this is indicative of a bad starter solenoid (which would keep the battery from being pulled down).
OP, please confirm. If the key was indeed held in START, then double-check that you are getting 12 volts to the 'S' post of the solenoid from the RED with BLUE stripe wire. If that checks out, then the solenoid needs replaced. They do come bad out of the box.
Sorry, I missed your instruction to hold the START position while taking readings. I'll shut up.
continue with FMC's last request for checking voltage at the S terminal....but I'm confused as to exactly what you meant by "If I go from the negative post to the solenoid post for the ignition it will turn over as well"??
What do you mean your switch is fine? There's obviously a problem somewhere. How can you tell what's fine and what's not so soon? I certainly can't yet, and I work on circuits for a living. Right?
Are you saying the RED with BLUE stripe wire leading to the 'S' post of the solenoid has 7 volts with the key in START? That's a useful data point. What voltage do you see on the inside of the wire boot coming from the RED with BLUE stripe wire with the wire removed from the solenoid, but the key still held in START (unless that's what you were already reporting)?
come on i need some advice please someone has to know
Take it easy friend! We don't monitor the forums on the hour or anything.
You're saying with the RED with BLUE stripe wire removed from the 'S' post of the solenoid, the voltage at this terminal with the key held in START is only 7 volts? There are two possibilities:
1) Faulty ignition switch. I'm not interested in what this switch does in another truck. That's an entirely new layer of variables.
2) START circuit is loaded down. The only other place the RED with BLUE stripe hot-in-START circuit runs to is the START input of the ignition module. One last thing you can try is to disconnect the 2-terminal connector leading to the ignition module, and repeat the measurement. If it goes back up to 12 volts from 7 volts, something is wrong with the ignition module, loading down the START circuit too low for the solenoid to make.
It's very unlikely there's a wiring problem. For wiring to be a problem and induce an unwanted voltage drop, there has to be current flowing through it, which would NOT be the case if the measurement was taken per my instructions.
