ECT live data = -160C???
Everything seems fine now, and starts/runs like brand new (actually, it starts better than ever before), builds and maintains fuel pressure that appears to hold solid even under max load.
I have been logging runtime data using DashCommand on an android phone, and a cheap ELM327 OBD module...
I noticed that the 'FORD.ENGINE.ECT' PID will show temperature readings only after the temperature gauge on the instrument cluster (the one on the truck, not the one on my phone), is up to normal range. As time passes, and the PID data indicates a temp of 250+ degrees F, it suddenly goes to some negative value. Once the temp falls below 250 F, Dash Command gauge starts indicating again...
(ok, sorry for all of that. now for the question...)
Anyone happen to know what's causing this behavior? The truck seems to run fine, and the temp guage in the truck never goes high or low of mid range until I've shut it down. Are there more than one coolant temp sensors on the early 99's?
Mine was made in 98 for the Canadian market, if that makes a difference...then later 'imported' into the US where I purchased it used...
As far as I know, the ECM is original to the truck. I'm second owner, but have had it since about year 2000 when it still had around 11K miles...
Thanks,
-Vern (aka Brutus Jr)
p.s., I also installed a cheap-o stuart-warner electric oil pressure gauge (0-100 psi) in the fuel system. Best thing I ever did! The gauge is mounted in the dash, and the sending unit is plumped into one of the ports in the filter bowl. Cost was ~$30! It helped me identify the problem when my OEM supply pump was dying/died...
, it's just that this is confusing...if that's true, and the ECU isn't reporting coolant temp, then what is my ECU reporting as the ford.engine.ect? In my case, the data clearly responds to engine load (i.e., goes up faster with increased load, and falls with decreasing load...). This isn't of huge concern, as I said the truck seems to run fine. But this data sorta has me scratching my head...
...and yes, my truck does have the automatic transmission...
I've logged that phantom PID more than once, and it's a confusing bugger. Maybe I'll decode it some day... but I do have insight on some of what it's doing. That's an experiment for another time, though.
All these years of driving gassers, we are brainwashed to thing the ECT is the big thing to watch. What we really want to watch on a turbodiesel is Engine Oil Temperature, Exhaust Gas Temperatures (both of them), and Transmission Fluid Temperatures. The ECT is close enough to EOT (usually within 10 degrees), that you can roll with EOT.
Oh... and you're missing out with Dash Command. You likely want Torque Pro.
1. Manual Transmission Equipped Engine Idle Strategy:
On Manual Transmission Equipped Models the Signal Voltage is part of the PCM Program Cold/Warm Engine Run Strategy and is received on Circuit #37 ensuring IVS Signal Voltage maintains idle..
2. Automatic Transmission Engine Idle Strategy:
On Automatic Transmission Equipped Models ECT is NOT part of the Cold Engine Run Strategy (EOT and IAT determines the IVS Signal Voltage for idling) Circuit #10.
When the EOT reached 130*F - 150*F (Circuit #38) on Automatic Transmission Equipped Models, the ECT becomes part of the Warm Engine PCM Program Strategy.
3. Monitoring the ECT:
Monitoring the ECT via the DLC will show erroneous "signal voltage" until the EOT reached the predetermined voltage programing data points to ensure the vehicle idles while in Gear. Then the ECT can be "seen" signaling the PCM. So, If you're monitoring ECT on an Automatic, it will never be correct until the above conditions are met.
ETC/EOC Differences. The ETC/EOC should be no greater than 15*F from each other. On Automatic Transmission Equipped Models its impossible to determine the differences as the test should be performed KOEO Cold Engine.
