Sponsored by: Real Truck
spike for trailer hitch
Old Sep 9, 2014 | 08:01 PM
speakerfritz's Avatar
speakerfritz
anyone know of a source for a trailer hitch spike. I have a hitch on both the front and back and am tired of folks bumping into my truck while parking.
want to put a 3 to 6 inch spike on each end so they will have a nice sized hole in their bumper.
I seen the hay spikes but they are 38 inches long....don't want to rupture gas tanks.
Old Sep 9, 2014 | 08:19 PM
ATP Pilot's Avatar
ATP Pilot
in some places it is illegal to leave your hitch on while not using it, because of the hazards The spike would be a good reason for a lawsuit in these areas.
Old Sep 9, 2014 | 08:26 PM
Punisher29073's Avatar
Punisher29073
Those are on aisle 5 next to the missiles that go behind your headlights.
Ryan
Old Sep 9, 2014 | 10:32 PM
NorEasterMA's Avatar
NorEasterMA
As tempting as this sounds, it's really not the best idea. It can get you in trouble if it causes real damage, because while you MAY be able to argue your case for having a hitch on the truck (I just came from a tow/going to a tow), you are going to have a very hard time explaining what exactly you're doing with a spike on the truck. I always have my pintle combo on the back of the truck, and even with this technically I can be faulted because some insurance companies don't like that. That being said, post some pictures if you ever get anything done about this, would be interesting to see!
Old Sep 10, 2014 | 01:25 AM
Yahiko's Avatar
Yahiko
There was one step unit that has energy absorbing
components in it like cars have in the bumpers.
SUPERBUMPER Hitch Step - Stops Rear End Collision Damage.
Old Sep 10, 2014 | 01:57 AM
Bently_Coop's Avatar
Bently_Coop
This is something else that may work. Not cheap but very functional. Shackle hitches.
http://www.bigas****ches.com/
Old Sep 10, 2014 | 05:41 AM
kd0axs's Avatar
kd0axs
I will agree that this is a bad idea. It will be pretty obvious that its only reason for being there is to cause damage, and you'll be responsible for any damage it causes. (even if it happened because they ran into your truck) Also, you certainly don't want anyone getting injured by it, especially someone's kid. Something like this could cause a serious injury if someone were to hit it while walking, and then you'll really have problems.
Are people really running into your truck that often that this is an issue? If so, I'd suggest that you get a low or zero deductible on your insurance for hit and run damage. While I've never had it happen to me personally, it did happen to my wife in her Jeep. Someone left this nice dent in the corner of the bumper and left:
Luckily we only have a $50 deductible for hit and run damage, and the check from the insurance company paid for this:
Sent from my HTC ONE using IB AutoGroup
Old Sep 10, 2014 | 06:24 AM
sammy77's Avatar
sammy77
Ryan
They moved the missiles to aisle 6..
I always leave my receiver in my hitch. I have been hit twice, back there and luckily never left a mark... for me anyways.
Old Sep 10, 2014 | 07:03 AM
Tom's Avatar
Tom
Sounds like you need one of THESE, not a spike. That would be a particularly malicious thing to put on your truck. Terrible idea for lots of reasons, and could very well give you trouble with the law and/or possible civil liability.
Old Sep 10, 2014 | 08:37 AM
speakerfritz
in NYC the parking technque used is back in til you hit the parked car behind you, then go forward til you hit the parked car in front of you, then back up a few inches. The drivers will get out and look at the impact areas for some reason, then move on. So i cant call this accidental.
so no, I do not want a horizontal bumper since its only going to get bent like the last one I had.
Yes, a spike will leave marks on the offending vehicle. I'll put a rubbr hose on the spike to keep blind people from getting scratched if they walk actoss the tip of the spike.
so back to the search, there are hay needles out there that mount in a hitch so, I guess I will get two of those and cut them down between 3 and 6 inches.
They only case I found of someone getting a ticket for a hitch device was for someone who had the two into one hitch that apparently violated the 8 inch protrusion rule of that state. There are no rules on this in NYS. and as the canadian folks know, in canada, you can not drive around with a hitch installed, ball mounted, if you are not on your way to or the way back from picking up a trailer.
Old Sep 10, 2014 | 08:59 AM
tjcprop's Avatar
tjcprop
First lift your truck 6 inches and use a lower trailer hitch. I was rear ended at a stop light and did far more damage to the truck that hit me than was caused to me truck. Second, install "Rhino guarded" running boards. This helps when people open vehicle doors in tight parking lots. Their doors gets the dings or dents. Third, install a plow on the front. This scares people from hitting the front.
Old Sep 10, 2014 | 09:01 AM
Iaff113's Avatar
Iaff113
Why not get two small receivers for the front and rear. And you could push and pull trailers also. I always leave my rear on in and always have people hit it.
Old Sep 10, 2014 | 09:19 AM
kd0axs's Avatar
kd0axs
You're not understanding the consequences of your actions here. This has nothing to do with it being a "hitch device". It has to do with the fact that you're essentially turning your truck into a weapon. The law follows intent, and it's clear that your intent is to cause damage to other people's vehicles should they happen to bump into your vehicle. If someone hits this spike and it damages their vehicle, you're going to be paying for the damage. If someone is injured by it, you're going to be responsible for their medical bills, and there could even be criminal consequences.
I'd just use one of these triple ball hitches. This will do some damage if someone hits it, while still being an actual trailer hitch. They're really not expensive either. I think mine was $35 and it's rated to tow up to 10,000 lbs. Some even have a tow hook on the 4th side.
Old Sep 10, 2014 | 09:34 AM
r2millers's Avatar
r2millers
What's wrong with them just hitting the hitch and ball? It won't do any damage to your truck, just tear up their bumpers anyways.
However,if you are going to do this, go all the way with the gas tank rupture device. Burn baby burn!
Old Sep 10, 2014 | 12:36 PM
Thenewboss's Avatar
Thenewboss
I use this...
Amazon.com: Smittybilt 27046B Beaver Step for 2" Hitch: Automotive Amazon.com: Smittybilt 27046B Beaver Step for 2" Hitch: Automotive
Very handy to have, useful in many ways, including yours
