c6 trans puking fluid
Old Sep 9, 2014 | 07:56 PM
Andy Mattingly's Avatar
Andy Mattingly
I need help. my 85 4x4 with the c6 is pushing fluid out of either the pump seal or torque converter seal. I have got my trans out and see nothing wrong with the seals. is there something that could build up pressure and pushing the fluid out or is it just leaking out of a seal.
Old Sep 10, 2014 | 08:03 AM
Franklin2's Avatar
Franklin2
If you overfill the tranny it will do that. If the tranny overheats it will do that also. I would go ahead and replace the seals if you are already there though.
Old Sep 10, 2014 | 12:12 PM
maytag906's Avatar
maytag906
I just went through this with a 97 F350, and an E40D overdrive. There was a factory auxiliary transmission cooler in front of the radiator, that started leaking. I figured something that small wouldn't matter if I bypassed it, the cooler in the radiator was still present.
WRONG!
The first long trip I took with it, fluid started pouring out in the area of the front seal/converter. I ended up losing the transmission, because the fluid ran low trying to get it home. My wallet is now about $2400.00 lighter, because of that missing cooler. Several people in the 92-97 section told me the same thing, that small cooler is vital.
Old Sep 10, 2014 | 03:01 PM
Andy Mattingly
thanks guys
eclypseballoons
Jan 23, 2014 09:45 AM
riverratmike
Modular V10 (6.8l)
27
Jun 29, 2013 07:48 AM
rwdfan
Mar 27, 2012 03:05 PM
gkbid
Jul 25, 2004 09:43 PM
NorthernStar
Aerostar
Jul 14, 2004 05:25 AM
