Stuck Autolite Glow Plug
Old Sep 9, 2014 | 10:28 AM
M82A1710M's Avatar
M82A1710M
Hello,
I am new here and hope to learn a tip or two.
The PO of my 1997 F350 installed Autolite GPs, got all of them out but the one for Piston #1. What happened is the cap securing the heating element to the top of the GP assembly popped off while ratcheting the GP out. I finished unscrewing the GP and the body of the GP came out leaving the whole length of the heating element securely stuck. No matter what I try I cannot get it to move up or down or around.
Thinking of pulling the hood and starting the engine to blow it out...thoughts/comments?
Thanks!
Old Sep 9, 2014 | 10:56 AM
nossliw's Avatar
nossliw
Blowing it out is your last chance, it will come out like a bullet so be careful. If it does not your head will be coming off...
Old Sep 9, 2014 | 11:17 AM
M82A1710M's Avatar
M82A1710M
What is the chance it could be sucked back into the pre-chamber or piston cylinder instead of shooting out of the head?
Old Sep 9, 2014 | 11:24 AM
williameub's Avatar
williameub
None.
But like the others said, if it comes out, make sure no one is around that could get hurt.
Old Sep 9, 2014 | 11:29 AM
richdawg's Avatar
richdawg
Welcome to
I am sure others will post on some realistic solutions to to your situation.
Don't loose your head, just give us a little more time
Old Sep 9, 2014 | 11:37 AM
M82A1710M's Avatar
M82A1710M
Thanks richdawg...thanks all! I'm on the verge or loosing my head. Your ideas for a good and hopefully easy fix brought me here.
Old Sep 9, 2014 | 12:35 PM
madpogue's Avatar
madpogue
Have you looked into the "slide hammer" trick? You take a vise-grip, remove the bolt, replace it with a longer bolt with some sort of weight slipped on it, clamp the vise-grip down on what's left of the GP. Then, when you yank on the weight, it has a slide-hammer pulling effect.
I take it you've soaked it in PB Blaster and/or carb cleaner?
Old Sep 9, 2014 | 01:22 PM
M82A1710M's Avatar
M82A1710M
Thanks! Yeah, tried the slide hammer and been soaking it in PB for a few days.
Old Sep 9, 2014 | 03:27 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I soaked it with pb blaster then tapped it down maybe a 1/4", then turned the motor over by hand to push the gp up. Repeated about 4 times and on the fifth it shot out . It worked well but I don't know how easy it would be with the motor in. Mine was on a stand.
Old Sep 9, 2014 | 04:29 PM
tjc transport's Avatar
tjc transport
i ain't rite
i never did this on a powerstroke, but it works great on an IDI.
what i do is spray liberally with PB Blaster. then i hook a reversable cordless drill to the glow plug.
slowly rotate the plug, and spray with PB while pushing down and pulling up.
the turning action with the PB lubrication will cut the tip down so it can be removed.
egregg57
Sep 15, 2014 04:27 PM
jarid.clapp
Jun 24, 2013 06:21 AM
jetact
Sep 14, 2010 09:30 PM
TucsonTripleB
Feb 4, 2008 06:32 PM
Olddog66
Dec 10, 2006 02:57 PM
