Offroad & 4x4
dana 44 gears
Old Jul 14, 2003 | 02:12 AM
checkyoursix's Avatar
checkyoursix
dana 44 gears
I have a 93 f150 4x4 with 3.55 gears. I would like to go to 4.10s but I heard the ifs dana 44 case would have to change if I went over 3.73s. Does anyone know if this is true? If so, how do I find parts to do that. I would appreciate any help. Thanks
Old Jul 14, 2003 | 10:29 AM
Blue96
Guest
Posts: n/a
dana 44 gears
Check out Randy's Ring & pinion.
Old Jul 14, 2003 | 11:21 AM
MustangGT221's Avatar
MustangGT221
dana 44 gears
Yes that's true, you'd need a new carrier. You can get any kind you want, open, limited slip, locker, selectable locker....or a spool if 4wd will only be used off road.
Old Jul 14, 2003 | 11:24 AM
mrwizard's Avatar
mrwizard
dana 44 gears
3.92 is the cutoff. Below that, your carrier will work, above that and you need a new one.
Old Jul 17, 2003 | 10:52 AM
okiebronco's Avatar
okiebronco
dana 44 gears
i thought 4.10 was the cut off.... or is that just with the dana 60?
Old Jul 18, 2003 | 12:41 AM
RCrawler's Avatar
RCrawler
dana 44 gears
D44 3.73 & down / 3.92 & up #
D60 4.10 & down / 4.56 & up
Jason
Radster
Dec 5, 2016 01:20 PM
Jonathan McManus
Nov 27, 2016 08:19 PM
KsHighboy
Aug 25, 2016 07:05 PM
jkuhane
Mar 17, 2012 05:59 PM
fordmaniac21
Mar 5, 2002 08:23 AM
