accelerator sticking
Old Sep 8, 2014 | 06:55 AM
myutesux's Avatar
myutesux
Hi all just need some help my accelerator is sticking and getting a bit dangerous foot pedal is not returning needing to lift back with foot I have tried WD 40 is their anything that will fix this from happening
Old Sep 8, 2014 | 09:37 AM
Harte3's Avatar
Harte3
A stiff return spring might help...but that doesn't necessarily address why it is sticking.
Old Sep 8, 2014 | 10:59 AM
ZarK-eh's Avatar
ZarK-eh
I would pull the parts and clean them up. Take the cable and oil one end and hang it until oil seeps out the bottom. What kinda oil? *shurgs* but I used synthetic engine oil or whatever I had around.
Pulling the pedal assembly and cable should make it obvious where the sticky is and oiling anyway should help it last.
Old Sep 8, 2014 | 12:44 PM
1986F150six's Avatar
1986F150six
Disconnect the throttle cable from the carburetor and then move the throttle arm to see if the carburetor is sticking. This will eliminate the cable.
Check to see if the carburetor housing is worn where the throttle plate/shaft exits the body. If much free play is evident, the throttle plate might be rubbing the inside if the throttle body causing binding.
pnp522
1983 - 2012 Ranger & B-Series
Feb 26, 2019 06:55 AM
big64
Apr 14, 2009 09:05 PM
runner
13
Oct 6, 2006 04:15 PM
water 5
22
Apr 6, 2006 09:53 PM
topohill
Nov 9, 2004 09:09 PM
