Sponsored by: Auxito
1998 5.4 engine locks up
Old Sep 7, 2014 | 06:06 PM
peppermrj's Avatar
peppermrj
Question 1998 5.4 engine locks up
I have a 1998 Scab 4x4 with a 5.4 automatic. Had some rear ring and pinion issues which i have repaired. the truck sat for almost a year afterwards before i started getting it road worthy. Battery was toast and the last thing i did. Tires, brakes, wheel cylinders, tranny lines, gas tank, ...
New battery and bang, boom, clank. Engine can be turned by hand but will lock up going in either direction. Serp belt is off, starter is off(chewed up some flywheel teeth when it locked), rear wheels turn, drive shaft turns, front drive shaft turns.
Cant hear anything obvious while turning the engine by hand. Going to pull the plugs next but dont think thers is any hydrostatic lock.
any thoughts? Dropping the oil pan will be next but not looking forward to that.
Old Sep 7, 2014 | 07:12 PM
Dr. Dirt's Avatar
Dr. Dirt
what does the coolant level look like? coolant in engine????
Squirrel Man Sam
Apr 2, 2018 02:40 PM
athawk11
2004 - 2008 F150
Jun 18, 2017 08:43 AM
Mudcut
1997 - 2003 F150
Apr 13, 2013 09:44 PM
cadillacmob
Sep 5, 2010 09:23 PM
elbowgrease
Large Truck
Jan 11, 2010 12:32 PM
