P0470 code help!!
Old Sep 8, 2014 | 07:08 PM
Rusty Axlerod's Avatar
Rusty Axlerod
So the same thing with both old and new Baro sensors? That's weird, seems like it would have to be the harness then. I feel like we're missing something easy here...
Old Sep 8, 2014 | 07:11 PM
2006powerstroke90's Avatar
2006powerstroke90
Sorry rusty poor explanation on my end!
I only changed out the MAP sensor as that's all I could get my hands on tonight.
I will have the new EBP sensor tomorrow-what I find strange is the sensor changes readings as driving-which to me would mean the sensor is working?
The BARO sensor I will have Wednesday.
Old Sep 8, 2014 | 07:19 PM
Rusty Axlerod
I think I have a copy of ALL the X-gauge threads lol, I looked through them and did find one alternate BAR gauge that may be worth a try.
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
Old Sep 8, 2014 | 07:33 PM
2006powerstroke90
WOW rusty I am an idiot. I guess that's what I get for rushing. I entered the info into my scan gauge Incorrectly. Damn.
This is with the BARO sensor plugged in
This is with the BARO sensor unplugged
I feel like such a jack *** entering the codes in wrong. Damn it what a waste of time.
I guess it's safe to assume at this point the EBP sensor is toast?
I really do appreciate your help!!
Old Sep 8, 2014 | 07:41 PM
Rusty Axlerod
Yes sir! That would be my next step. With the -.5 bias I would expect EBP to be a little lower than Baro or MAP. Hope that fixes it.
Old Sep 8, 2014 | 07:50 PM
2006powerstroke90
Yeah me too! Can't stand having issues. Thanks against for your help! Will post back tomorrow
Old Sep 8, 2014 | 07:59 PM
Rusty Axlerod
You're welcome. Hope that turns out to be the issue, if not, you still need correct EBP numbers to troubleshoot further so on the right track anyway. Did you clean the EBP tube when you cleaned the sensor? If not you may want to run some weed eater line or something through there while the sensor is off just to make sure it's clear.
Old Sep 8, 2014 | 10:11 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
I'd try a wiggle test on the ebp harness n wiring koeo. Watch for it to change. I had one last week that was showing 11.1,,, anyone guess what happened with that truck?? PCM tried to pick up the slack for low ebp,, fried the unison ring and actuator arm over boosting,,, and toasted the hg's. At least your numbers (at 18 koeo) will cause UNDER boost. That's HG safe.
Old Sep 9, 2014 | 05:26 AM
2006powerstroke90
Yeah, I tried that. I'm going to see if I can get a new pig tail for that sensor and replace that as well
Old Sep 9, 2014 | 08:16 AM
2006powerstroke90
I probably smoked the EBP sensor when I used brake cleaner to clean out the sensor-I have the new EBP sensor in hand-just have to wait until 6 to put it in.
Old Sep 9, 2014 | 06:16 PM
2006powerstroke90
Truck is fixed!!!
The new EBP sensor fixed it.
MAP 14.6
BARO 14.6
EBP 14.9
Awesome! Thanks for all your help.
Old Sep 9, 2014 | 07:39 PM
Rusty Axlerod
Glad ya got it
RazorbackF150
2009 - 2014 F150
Jul 9, 2019 09:04 PM
Leon_D
6.4L Power Stroke Diesel
Jul 28, 2013 11:38 PM
KrAzYKARL
2004 - 2008 F150
Sep 4, 2011 07:26 PM
cdiddy
Dec 13, 2007 11:34 AM
jake00
General Automotive Discussion
28
Jan 28, 2006 09:42 PM
