1968 F100 timing issue
Old Sep 11, 2014 | 07:26 PM
Tedster9's Avatar
Tedster9
Where did I say that?
Old Sep 11, 2014 | 08:27 PM
williamwilliam's Avatar
williamwilliam
Originally Posted by Tedster9
Have pondered this, and how it would throw timing light indications off. On a Y Block - 15486372 - each cylinder TDC being 1/4 turn of the crank of course but - one tooth off clock index either way of the distributor doesn't equal one cylinder, tho it would throw the timing light off enough to be a head scratcher, I guess.
That's why vacuum gauges are nice. My 64 at first - had the distributor cap clocked 180 out, plus the damper slipped almost 10 degrees, and at that time had hardly a clue what engine timing was about. Figured out #5 was my #1, but never had it running right with a light. Until I got all that straightened out, just timed it for max vacuum at idle -1 in. And that was about perfect. Replaced the damper, and worn out distributor, runs a lot smoother and takes the guesswork out. Now I could time it by ear! Runs about 14-16 deg. initial at max vacuum iirc, 24 mechanical, all in by 3000, runs a lot better.
Post #12.....unless I misunderstood and you was talking about something else.....never hurts to ask though.
Old Sep 11, 2014 | 09:19 PM
Tedster9's Avatar
Tedster9
Damn son, see where it sez "On a Y block" ?
As an aside, there are actually only a few firing orders. 15486372 is the correct one.
Old Sep 12, 2014 | 04:44 AM
williamwilliam
Well, what I was saying was the correct one for a 360/390 is 15426378, that's on all FE engines so I was making sure that was the firing order you have on your 390 or 360 that is in your truck.....seems like you didn't know since you said you would "have to check". Good luck to ya.
Old Sep 12, 2014 | 07:58 AM
Tedster9's Avatar
Tedster9
It's easy to confuse who is posting what sometimes in a thread. If I got a 390 in my truck it's news to me!
Originally Posted by williamwilliam
... the firing order you have on your 390 or 360 that is in your truck...
Old Sep 12, 2014 | 03:49 PM
williamwilliam
LOL, I see now it was johnie ryall who started the thread and has the 360/390.....I just got confused and thought you started the thread when we quoted each other. Guess I should have went back and read the original post before saying something. Sorry!
john jamieson
17
Oct 12, 2015 11:32 PM
Spoonman75
Sep 7, 2015 11:34 AM
wiznozniak
Oct 21, 2011 10:54 AM
Riderman
34
Jan 11, 2010 11:01 AM
sisu1a
Aug 29, 2005 12:20 AM
