Keeping front leaf springs
Old 09-06-2014, 07:28 AM
bokker's Avatar
bokker
bokker is offline
Hi, on my 1950 F1 I have posie front springs and have now cut down the bump stops to gain the correct movement so my question is - how do I stop the front end being choppy over uneven roads. I have nitrogen filled shocks but it still wants to bottom out and top out over the bumps.
Has any one fitted harley air shocks in place of the dampers ? If so any good ?
On a good road it's great but on a bad road it's real bad. All the minor roads in the uk are bad due to frost damage and that where I do most of my driving.
The F1 has disc brakes and power steering so I am not going to change the front suspension to ifs so if any one has a solution to my problem it will be much appreciated . Thanks bokker.
Old 09-07-2014, 09:52 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I would suggest contacting Posies directly (POSIES Rods and Customs). They don't just make springs they build really nice street rods. I have been to their shop.
I don't know what gas shocks you are using but they recommended Bilsteins for my truck.
Old 09-07-2014, 12:13 PM
AXracer's Avatar
AXracer
AXracer is offline
Buy some high quality shocks! Since you are in the UK, Konis would be a good choice, Bilsteins are also good.
Old 09-07-2014, 12:22 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
IMO, you're going to need a higher spring rate or more suspension travel to eliminate the 'bottom out'. How much suspension travel do you actually have?
Old 09-08-2014, 02:31 PM
bokker's Avatar
bokker
bokker is offline
Hi, thanks for the replies . Looks likes different shockers are on the cards. I have only 2 inches of movement before bottoming out and that's cutting the bump stops to a minimum . Posie recommended cutting the bump stops and if need they would send me their own short units.
Thanks for all the advice I will try to fit the harley air shocks as this will give me stronger springs and good damping. Bokker.
victoriavet
04-06-2011 04:48 PM
tomtoc
07-09-2007 05:09 PM
MMarty
06-30-2006 03:10 PM
JoeSwing78
20
12-20-2005 02:34 PM
79'Ford
Offroad & 4x4
07-25-2005 12:41 AM
Quick Reply: Keeping front leaf springs
