Keeping front leaf springs
Hi, on my 1950 F1 I have posie front springs and have now cut down the bump stops to gain the correct movement so my question is - how do I stop the front end being choppy over uneven roads. I have nitrogen filled shocks but it still wants to bottom out and top out over the bumps.
Has any one fitted harley air shocks in place of the dampers ? If so any good ? On a good road it's great but on a bad road it's real bad. All the minor roads in the uk are bad due to frost damage and that where I do most of my driving. The F1 has disc brakes and power steering so I am not going to change the front suspension to ifs so if any one has a solution to my problem it will be much appreciated . Thanks bokker. |
Originally Posted by bokker
(Post 14644028)
Has any one fitted harley air shocks in place of the dampers ? If so any good ? On a good road it's great but on a bad road it's real bad. All the minor roads in the uk are bad due to frost damage and that where I do most of my driving. The F1 has disc brakes and power steering so I am not going to change the front suspension to ifs so if any one has a solution to my problem it will be much appreciated . Thanks bokker. I don't know what gas shocks you are using but they recommended Bilsteins for my truck. |
Buy some high quality shocks! Since you are in the UK, Konis would be a good choice, Bilsteins are also good.
(Post 14644028)
Hi, thanks for the replies . Looks likes different shockers are on the cards. I have only 2 inches of movement before bottoming out and that's cutting the bump stops to a minimum . Posie recommended cutting the bump stops and if need they would send me their own short units.
Thanks for all the advice I will try to fit the harley air shocks as this will give me stronger springs and good damping. Bokker. |
