Help!!!! Dually wheel!!!
Old Sep 11, 2014 | 04:52 AM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Rogue_Wulff
The very thing that DOT inspectors will shut down a semi for doing. Doesn't make sense, but what does where the feds are concerned........
Wrong.
Originally Posted by 82F100SWB
Not legal? Never heard of such a thing, lots of big rigs come out of the factory just that way with a plastic shim between the wheels to prevent corrosion.
Unless it is some sort of weird law that they only enforce on US registered trucks and let us canucks slide when operating on your side of the border.
Correct. brand new trucks leaving the factory are built this was and are 100% LEGAL
Old Sep 11, 2014 | 07:06 AM
Rogue_Wulff's Avatar
Rogue_Wulff
They weren't back when I was driving them. That has been a few more years than I really wanna admit to though.
I always though it was odd that a "1 ton" could run allow and steel together on the same hub, with a single set of lugnut, and a bigger truck wasn't allowed to do so even though they had inner & outer lugnuts.
Old Sep 11, 2014 | 10:50 AM
Franklin2's Avatar
Franklin2
Is it correct what I have heard, that aluminum wheels on dump trucks and semi's are for weight purposes? If you save 500lbs in weight with the aluminum rims, that means you can haul 500lbs more gravel per trip. Don't know if that is the real reason or not.
Old Sep 11, 2014 | 11:03 AM
raytasch's Avatar
raytasch
Believe Nothing
You're going to need some long lug studs to run dual aluminum wheels. BTW, my new E 450 SD had Alcoa wheels outside rear and on the front. Nothing between the duals to prevent corrosion and they were stuck.
Old Sep 12, 2014 | 04:57 AM
Diesel_Brad
The problem is More than the studs.
The machined hub that centers the wheel is NOT big enough to hold 2 aluminum wheels.
In order to run dual aluminum wheels safely on a dually pickup you need a spacer that bolts on with the inside wheel. It then had 8 new studs with a hub centric lip for the outer wheel
Kountryguy
Jul 9, 2019 09:38 AM
lawnspecialties
Jan 26, 2014 08:27 PM
threefiftyone
Oct 4, 2005 01:12 AM
tthaguy
2004 - 2008 F150
May 11, 2004 03:42 PM
