No acceleration
Old Jul 13, 2003 | 08:23 PM
moose94's Avatar
moose94
No acceleration
Well, I have a '94 F150 XL 4x4 (w/33" tires and an K&N air filter) and I think I need lower gears, because when I try to accelerate on the highway I can't.
It's almost like she has nothing left. I try to pass people but find my foot going all the way to the floor, and there is still nothing. Offroad she doesn't work well either. It works sweet in 4x4 low, but other than that it's not good.
I also want alittle more grunt! I want to be thrown back in my seat when I punch it.
There is however some things I need, which is descent gas milage. I know right now I don't get any, but my buddy has 4:56 gears in his truck and it's really bad on gas!
What are my stock gears? Would 3.73's be good?
I don't need my truck to go like 180 KM/h, I only drive 90KM/H, but I'd like to have that kick when I go to pass.
Any help would be greatly appreciated.
Old Jul 13, 2003 | 08:45 PM
MustangGT221's Avatar
MustangGT221
No acceleration
There is a tag on the rear diff that will tell you what the ratio is. Most likely it's a 3.55. You'll want 4.10s for a good mix of gas mileage and power.
Old Jul 13, 2003 | 09:00 PM
moose94's Avatar
moose94
No acceleration
sweet. Um are 4.10s decent for top end speed?? Would I see a noticable difference?
Old Jul 13, 2003 | 09:19 PM
moose94's Avatar
moose94
No acceleration
Do I have an 8.8 or a 9" rear end?
Old Jul 13, 2003 | 09:51 PM
MustangGT221
No acceleration
8.8 and you'll need some for the front end. I just did this, I got 4.10 ford racing gears (190 bucks), summit install kit ($80) for my 8.8. Then I got the Dana Spicer 4.09 gears for the front which already comes with an install kit for 188 bucks. Top end shouldn't change much. I don't know if you have an automatic or manual, but you'll be running about 2100 RPM at 70 mph in overdrive.
Old Jul 13, 2003 | 10:02 PM
moose94's Avatar
moose94
No acceleration
I have a standard 5 speed. I am about 1900 RPM at 95 KM/H.
Old Jul 13, 2003 | 11:06 PM
MustangGT221
No acceleration
OK, you'd be at 2300ish with a 5 speed (thought you had an automatic). What's 95 KM/H....59-60 mph? AT 70 mph you'd be at 2300ish, at 60 mph you'd be at 2000. Doesn't sound like much, but your speedometer might be off as if you do the math with your current setup, it should read 1700 if you have 3.55s. Check the tag on the rear differential cover and see what gears you have.
Old Jul 14, 2003 | 12:14 AM
carpe_diem's Avatar
carpe_diem
No acceleration
That's the compromise - lots of towing torque, low end power but no acceleration or passing at 65. You floor it - and nothing. That's how my 460 works too, with 4.10.
Tons of acceleration and torque at low speeds. I think from the stop light it can outrace most cars - that is until it hits 35 mph.
Old Jul 14, 2003 | 10:09 AM
moose94's Avatar
moose94
No acceleration
So what do I do? If I get 4.10's what will that mean? Will I be able to pass people on the highway? Or is it a waste of money, time and gas?
kornfanjoe
Dec 29, 2012 11:30 PM
Betaracer
Sep 19, 2005 04:56 PM
omnithesis
Aftermarket Products
Jun 2, 2004 02:48 PM
moose94
Aug 27, 2003 11:27 AM
myvan
Aerostar
Jul 7, 2003 11:10 AM
