tach for 300 i6
Old Jul 25, 2003 | 10:30 PM
ewellman's Avatar
ewellman
tach for 300 i6
I am looking at putting a tach in my 92 f150 2x4 300 i6.
Any idea which one to look for. Looking for low cost. 2nd how hard is it to install? What is the procedure?
Old Jul 27, 2003 | 04:03 AM
Pkupman82's Avatar
Pkupman82
tach for 300 i6
Tachs are easy to find, you can get one at Autozone for 40 bucks. I got a Sunpro SuperTach2 for $40 and installed it on the steering column on my 84 with a simple 4inch stainless steel hose clamp. Wiring is easy 4 wires sometimes 3: Black- ground, Red- power only with ignition on, Green- negative side of the coil, and White- wires into your instrument cluster lights (some tachs do not have a lighting wire) .
Old Jul 28, 2003 | 11:22 AM
TallPaul's Avatar
TallPaul
tach for 300 i6
See mine in my gallery. $65 at JC Whitney. Lighting is poor (I have found this on other tachs, including one by Autometer), but the face is huge and the max 4000 rpm is perfect for the 300 I6. Also the mounting location is pretty good.
Old Jul 28, 2003 | 01:45 PM
jamesmonty's Avatar
jamesmonty
tach for 300 i6
You might be able to find a stock tach out of a manual truck. My truck used to be a 5-speed so it has a factory tach in the dash. I don't want to say for sure, but it might already be wired up for one (I could be wrong). Might be worth checking out.
Old Jul 28, 2003 | 06:14 PM
serving_time's Avatar
serving_time
tach for 300 i6
Look for the entire guage dash piece out of a truck that was a standard at the wreckers. It should be just plug and play. At least mine was in my 1991.
Old Jul 28, 2003 | 09:35 PM
wildjon300ci's Avatar
wildjon300ci
tach for 300 i6
My 1985 was a plug and play affair...as long as you have actuall guages and not idiot lights it is plug and play.
Old Jul 29, 2003 | 04:49 AM
Pkupman82's Avatar
Pkupman82
tach for 300 i6
I hate idiot lights, when they turn on it's already too late!
Old Jul 29, 2003 | 10:46 AM
guitarplayer_101's Avatar
guitarplayer_101
tach for 300 i6
Originally posted by jamesmonty
My truck used to be a 5-speed so it has a factory tach in the dash. I.
Same here! But mine still is the 5-speed.
Old Aug 1, 2003 | 06:04 PM
javi2001's Avatar
javi2001
tach for 300 i6
If you want precission look at www.datcon.com
Old Aug 1, 2003 | 11:07 PM
cocot's Avatar
cocot
tach for 300 i6
Try Ebay. I paid $15 including shipping.
Old Aug 2, 2003 | 01:46 PM
ewellman's Avatar
ewellman
tach for 300 i6
thanks guys. I looked into a factory guage cluster and all I could find was one for $100 plus and I don't even know if they have a tach or not. (looked on internet) For now I put a $30 Super Tach II from O'Reilly's in until I can find a factory cluster.
Old Aug 2, 2003 | 10:49 PM
Vampiro's Avatar
Vampiro
tach for 300 i6
walmart 32 bucks roughly taxes inc. in canadain dollars
easy to connect. 1 to the tach test on the coil then a power and ground wire. thats it
