need help need advise
Old Sep 3, 2014 | 02:22 PM
krnqtxboi84's Avatar
krnqtxboi84
Unhappy need help need advise
i guys im new here... I have question.... I have 02 excursion limited 4wd with stock suspension. And... I jus order procomp 6inch lift kit (4018B) and 37 15.5 tire..
Some one told me its ok to fit 37. But someone said need Re-aligned the v3 line with master bolt and if I put 37s I might broke my PDR (Protruding de-simitator retractable)
Is there anyone have 6inch lift kit with 37s on it?
What do I have to change to fit 37 on my excursion...
Old Sep 3, 2014 | 08:48 PM
jayjjcc's Avatar
jayjjcc
So you wanna know if 37s will clear a 6" lift?
Old Sep 3, 2014 | 09:01 PM
krnqtxboi84
Yes sir. I already purchased 6 inch lift kit procomp (4018B) and 37 13.5 tire... its on the way. But I jus wana make sure it fits or I need add something.....
Old Sep 3, 2014 | 11:22 PM
GermanMike's Avatar
GermanMike
If you ordered a 6" procomp set you will get about 8" of Lift installed on
our EX. That is enough lift to get clearance depending on your rims backspacing.
BUT........
You will need a lowered Pitman Arm
You will need a lowered Track Bar Bracket
You will need probably an adjustable Track Bar (Depend on your choosen Bracket)
......and with 37" you want to regear your diffs to 4.88 or 5.13. Atleast 4.30
to get your OEM ratio.
Nathan6.8
Aug 18, 2010 03:53 PM
scottman70
Dec 5, 2006 10:14 AM
nserpa9248
Jul 26, 2004 07:57 AM
JoeBob1901
Offroad & 4x4
15
Mar 3, 2004 10:28 AM
mjeckell
Dec 6, 2002 05:56 PM
