Second sensor failure
Old Oct 21, 2014 | 07:29 AM
  #31
Big Red 5205's Avatar
Big Red 5205
I guess if I get the truck back today, I will find out if it's another bad sensor, bad DEF tank sensor or something screwed in the PCM giving false readings.
Old Oct 21, 2014 | 11:01 AM
  #32
FordService's Avatar
FordService
Official Ford Rep
Any news from the dealership today, Big Red 5205? I'm here if you need me to step in and help.
Crystal
Old Oct 21, 2014 | 02:12 PM
  #33
Big Red 5205
The truck is at Gilbert Ford in Okeechobee, I just talked to them and they are still running tests, they said they run a test then call a factory tech with the results and I won't have my truck back today. I just want it FIXED, so if it takes another day, that's fine with me.
It does feel weird driving a little F-150 gasser.
Old Oct 21, 2014 | 02:16 PM
  #34
Big Red 5205
Didn't mean to hijack this thread, but this sounded like my issues.
Old Oct 22, 2014 | 09:37 AM
  #35
Big Red 5205
Got another call from the dealership this AM. All their tests are pointing to a faulty PCM. They have been talking with corporate, corporate says; that's a $1000 part, do some more tests. The diesel tech that had been doing the tests had to go out of town till next Monday and that leaves the dealership with a brand new tech to do a pinpoint test and make a discussion on my truck. Gilbert Ford has been great so far with keeping me informed and with a loaner F-150. Service manager asked if I can wait till next week for the return of the original tech. Don't need to haul horses or John Deere this week so I agreed. Saga continues till next week,
I'll keep you informed!
Old Oct 22, 2014 | 09:56 AM
  #36
FordService
Official Ford Rep
...Saga continues till next week,
Thanks for the update, Big Red 5205! It sounds like your dealership is doing all they can to help, but if you'd like me to check out some additional ways to assist, just send me your info in a PM and I'll start researching. In your message, be sure to include your full name, best daytime phone number, VIN, mileage, and servicing dealership.
Crystal
Old Oct 23, 2014 | 05:38 AM
  #37
RangerSmith's Avatar
RangerSmith
I live in and bought mine in Okeechobee. I will not have anything to do with them as far as service or sales. They have one diesel tech and the sales manager changed the deal when I went to pick up my new truck. Changed my financing and my trade deal which I had in writing. The truck I purchased wasn't even the same one when I picked it up. Had different vin and I had deposit on original one with insurance in place and everything. If I were smarter I would have told them to keep it.
Old Oct 27, 2014 | 10:42 AM
  #38
2piecespecial's Avatar
2piecespecial
All Whining aside, how many 2013 and NEWER Trucks have had EGT sensors go bad??? I have not heard of a single one on any of the Forums. That being said, I do carry a spare sensor and a 13mm wrench along with a spare set of fuel filters in my truck just in case. Seriously. I have not heard of 1 bad EGT sensor on the '13 and Newer Trucks. All those who have had issues let us know.
Old Oct 27, 2014 | 04:12 PM
  #39
Goof18's Avatar
Goof18
Originally Posted by djousma
Odd. From the reading I've seen here, when the last one (EGT14) fails, thats the one that sets the "pull over safely" message, and shuts the truck down.
My truck has had the sensors **** it down twice in the last month. The first one was sensor 13 so I'm guessing 13 and 14 will throw the warning and if you're going under 20mph it'll kill your engine. I made it home from about 300miles away with that happening by mashing the a pedal and temporarily bypassing the shutdown. I only did that because I was in west Texas near pecos and oil field traffic will kill you if your on the side of the road. Crazy that they programmed it to kill the engine completely! It's not safe at all
Old Oct 28, 2014 | 04:13 PM
  #40
Big Red 5205
Well, I got my F-450 back from the dealership after they had it for numerous days conducting tests to find the faulty part giving me the "DEF 500 miles to empty". No codes and the message cleared while they were diagnosing. They were initially thinking it was a PCM problem but that checked out OK. So nothing was found and no parts replaced, that's good for Ford and if it never comes back, it will be great for me. Only time will tell!
Service dept. was frustrated that they could not find the fault and give me the true cause and I understand how these kind of things go, they are hoping that the disconnecting, cleaning and reconnecting of the terminals fixed it.
Old Oct 31, 2014 | 05:13 PM
  #41
Goof18's Avatar
Goof18
2 sensors came in today, swapped the bad one out and have a spare n 13mm wrench in the glove box. Simple fix, I hope this never hits in traffic while towing or at the launch. Thanks for the info
Old Oct 31, 2014 | 08:02 PM
  #42
BrodyUSMC's Avatar
BrodyUSMC
Ok New guy here and is this a part that I should cary with me? how many are there and are they all the same or do I have to have many spares? If not what one do I need to get and where is it at.. so if mine goes I willnot be stranded I live in the middle of nowhere in the desert.. thanks Oh yea what kind of scanner do I need to get to tell me what one is bad
Old Oct 31, 2014 | 09:14 PM
  #43
Goof18's Avatar
Goof18
I believe there are 4 sensors down there near the DPF and all are the same type/part number. I would keep a spare in the truck as well as a 13mm wrench. If the sensor for out it'll throw a warning telling you to "STOP SAFELY NOW!" And then it ****s your truck down for 60minutes. It's an easy fix though, 5 minutes n they're swapped out.
Old Nov 4, 2014 | 04:36 PM
  #44
Goof18's Avatar
Goof18
Got to drive my truck for 3 days and now it did the shut down routine again, this time throwing a P200E instead of the C code like it did the last 2 times...I can't win with this truck...��
Old Nov 10, 2014 | 09:30 AM
  #45
2piecespecial
Got a tip from a buddy who has had this issue. When his truck shut down from a bad sensor he merely took the sensor out and cleaned it off then reinstalled said sensor and drove home. To this day the same sensor is working fine and he has not had to replace this. perhaps this is one of reasons FoMoCo has stopped selling these...
