2010 Screw Transmission problems ?
Old Sep 2, 2014 | 09:13 AM
hemm's Avatar
hemm
I looked but didn't see this topic....being new its possible I didn't look in the right place.
Ok, here it is: F-150 XLT SCREW 4.6L V-8 4X4
I bought the truck used from a dealer (not Ford), it came with "Carfax" and that says the tranny was replaced before I bought it by the original owner at a Ford dealer, I don't recall if it says why it was replaced.
Bought it in April 2014, with 36,000 miles on it, now has 39,700 miles. No long trips and I haven't towed anything with it but a log splitter.
What happens:
Driving normal, 45-50 mph. Then as I roll up to a stop light to stop, just letting it power down by itself, letting off the gas, when it gets down to 25mph, its like it comes out of gear, then jerks back in with a clunk. It’s very noticeable and irritating.
Definitely not something I am willing to live with mostly because its not normal and feels like it could be tearing something up.
Anyone have a similar experience, how did you fix the problem?
Any useful "key words" to tell the dealer when I take it in that will save them and me time and money?
I promise to post updates and what happens along the way until its fixed.
Thank you in advance!
Last edited by hemm; Sep 2, 2014 at 09:36 AM. Reason: a bunch of extra stuff showed up that I didn't type.
Old Sep 2, 2014 | 12:08 PM
bigdaddyII's Avatar
bigdaddyII
I don't know if this is the same issue but my 2012 with the 5.0 tends to have a rough 2-1 downshift around the same speeds. It doesn't happen all the time and has done it since new so I figured it was normal, or at the very least the truck is under warranty. It hasn't seemed to cause any problems though. This is the 1st vehicle I have owned with a 6 speed auto and there were a lot of quirks native to the 6 speed I had to get used to and probably I filed that as one of them. Good luck getting your issue worked out though. Your truck is under power train warranty for 5 years, 60,000 miles though so you may want to start persuing this with your dealer if it will cause problems later.
Old Sep 2, 2014 | 04:29 PM
meborder's Avatar
meborder
there were some complaints about the shift patterns in the 6 speeds that were put into the 2009-10's. ford did two things to address these concerns.
1. redesigned the transmission for 2011
2. offered a revised shifting strategy for 09-10.
i'm not sure that there are any key words to ask your dealer, but i would stop in and tell them what it is doing. from there you could ask them to verify that it has the most current shifting strategy program available for your model year.
my guess is that the program was never updated, and there is a good chance that the update would aleviate your symptoms.
they may tell you that it is because of the vehicle's adaptive shift strategy, and that may be true. they will usually start by clearing out all of the learned behavior and let the truck relearn how to shift. this is common practice and sometimes does the trick. the learning procedure is kind of slow, so it does take a while for it to relearn.
good luck and keep us posted!
Old Sep 3, 2014 | 08:26 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by hemm
...I promise to post updates and what happens along the way until its fixed...
Any news from the dealership yet, hemm? I'll keep checking in on this thread in case you need my assistance.
Crystal
Old Sep 3, 2014 | 07:01 PM
hemm's Avatar
hemm
Crystal
Hi Crystal,
I have not been able to get to the dealer yet, literally in between changing jobs and regular meatworld stuff.
I hope to get it in there in the next 2 weeks.
Hemm....
Old Sep 3, 2014 | 07:05 PM
hemm's Avatar
hemm
This is interesting, and in fact a little disheartening.
https://www.ford-trucks.com/forums/1...nsmission.html
I will still get it to the dealer if for no other reason having the issue documented.
I just hope I don't get sucked into a newer model while I'm there......that all Aluminum model looks pretty darn good!!
Old Sep 4, 2014 | 08:13 AM
FordService
Official Ford Rep
Hi Crystal,
Hemm....
I completely understand, Hemm. Keep us posted.
Crystal
mr clutch
6.7L Power Stroke Diesel
357
Oct 23, 2015 09:51 AM
IRONTEK
Apr 3, 2015 01:53 PM
fordpstroke11
2009 - 2014 F150
22
Jan 11, 2015 05:24 PM
F2502011
Jun 6, 2011 08:46 PM
tiger1973
1997 - 2003 F150
Mar 11, 2003 07:00 PM
