"Sevice engine soon" light
Old May 9, 2003 | 04:07 PM
rvfiver's Avatar
rvfiver
Question "Sevice engine soon" light
What the are the different causes of this light to come on? It came on a couple of days ago, I reprogramed the chip with the microtuner, it went away for about a day or so then came back on again. What should I be looking for?
Old May 9, 2003 | 06:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There are dozens of things that will set an SES light. The more common codes resulting from chips/programmers are overboost, and ICP signal out of range.
Is the light constantly on?
Old May 9, 2003 | 06:59 PM
02superstroker's Avatar
02superstroker
was it the service engine soon or the check engine light? i have the check engine light come on occasionally come on from my chip when i really get on it. I looked up in the manual and this light was ..of course...an emmisions sensor. I havnt had the service engine soon light come on.....best of luck, maybe ken knows lol
Old May 9, 2003 | 07:00 PM
rvfiver's Avatar
rvfiver
Yes, the light is on all the time. It's not from overboost though, I haven't had it over 2000 rpm sence I last programed it and the light was turned off. It came back on today. Won't go off unless I reprogram it again.
Old May 9, 2003 | 08:49 PM
cookie88's Avatar
cookie88
FTE Emeritus
Unfortunately you're going to have to take it somewhere to get the codes pulled, unless you have the new microtuner that will read them.
Autozone does it for free, but the el crapo scanner they use only pulls generic codes, so you might end up at a dealer
Old May 11, 2003 | 02:53 PM
rvfiver's Avatar
rvfiver
I wish I did have the 1705 tuner to check the codes with, but that is not the case. Guess I'll have to take it in to the dealer and have it checked out. Seems to run just fine, haven't noticed a single other thing wrong, except that the service engine soon light won't stay off. Thank for all your help guys!
Old May 16, 2003 | 07:02 PM
rvfiver's Avatar
rvfiver
Well I went out and bought a OBD ll code reader ($140) to try and figure out the problem. Pretty neat device I must say. It not only reads the codes in about 10 seconds, it also lets you erase the codes and reset the computer and can even tell you if the work was done correctly. The codes I pulled were PO677 and P1112. One has to do with the "cylinder 7 glow plug circuit", the other, "Intake air temperature circuit". Not sure exactly what this all means, but I now at least know where to start.
