surging rough ide ,shaking
Old Sep 1, 2014 | 05:56 PM
the winemaker's Avatar
the winemaker
I have a 2003 f350 6.0 KR with 153kms or around 95000 miles.For the last year or so what I think is called the trubo fart ..when pulling 5th wheel up hills but does not happen all the time and when I do not have 5th wheel on truck works fine up until today .Coming back from camping for a few days had a little bit of coughing farting from the truck when pushing up hills.THEN as I was backing into driveway with 5th wheel truck was running rough and shaking at idle and shook when backing tlr up.I am going to get truck fixed if I can ever find out whats going on as this is a new problem this shaking, rough idling . Would it show a code if I had it scanned?? I sure would like some help on this ,has anyone else who has a 6.0 had same problem and what did you do to correct it?? thanks in advance for any help...the winemaker
Old Sep 1, 2014 | 07:52 PM
CPB1's Avatar
CPB1
Subscribed
I am having similar issues.
Old Sep 1, 2014 | 08:14 PM
78fordman's Avatar
78fordman
I would definitely get scanned for codes, even if the check engine light is not on.
Old Sep 1, 2014 | 08:36 PM
the winemaker
surging,rough idle,shaking
Chuck..what are you planning on doing about this problem?? Do you have problem with turbo fart??
Old Sep 1, 2014 | 10:53 PM
CPB1's Avatar
CPB1
No, no turbo fart. Mine is a bad miss, rough idle, and some black smoke along with a dead pedal at times.
Not sure what to do at this point, set it on fire maybe?
I can tell you what was recommended to me and what I have done so far.
Changed the fuel filters, remove and inspect FICM, monitor FICM volts, bubble test, fuel pressure test. All the tests checked out good so far. I am going to remove and inspect and/or unplug EGR valve even though I have a cooler delete. Then change tunes.
Old Sep 2, 2014 | 06:16 AM
mustang_309's Avatar
mustang_309
The shaking and rough idle sounds like a dead injector, that is exactly how mine was when I had #2 injector die. You would be amazed at how bad it will run with one bad injector. I would definitely have it scanned for codes. But you can also unplug 1 injector at a time to see which one makes no difference to how it is idling to find the offending injector.
Old Sep 2, 2014 | 04:18 PM
the winemaker
surging,rough idle shaking
Well had truck scanned and looks like TO START, no 5 injector is bad and going to get EGR cleaned and then I will see ..Taking it in the am to be fixed..Just a note my brother 2003 f350 6.0 had somewhat same problems ,he had scanned this pm and found his no 4 bad so he s going for new one and egr cleaning..thanks for help out there ..
Chris51080
May 11, 2023 09:56 PM
travelergypsy
Oct 9, 2018 08:52 AM
juang
May 22, 2004 05:59 PM
spitball
Mar 31, 2004 10:03 AM
