Sponsored by: Auxito
Help!
Old Sep 1, 2014 | 05:08 PM
dgford99's Avatar
dgford99
Help!
question to anyone with experience with 99's V6 4.2. just had intake gaskets replaced, still not running right. Tends to buck a bit when I go to accelerate from a stop. Replaced VMV, still not the problem, thinking it may be the charcoal canister. any other suggestions ?
Old Sep 3, 2014 | 08:19 PM
Dr. Dirt's Avatar
Dr. Dirt
is there a CEL on or anything?
Old Sep 4, 2014 | 03:56 AM
dgford99's Avatar
dgford99
To Dr.Dirt
not at the time, but it recently did come on. Lean codes p171&174, banks one&two, have had all obvious vacuum lines done, Mass air flow sensor has been replaced, I think now it's both air and fuel. Your thoughts on it. Thank you
Old Sep 4, 2014 | 07:09 PM
Dr. Dirt's Avatar
Dr. Dirt
no broken vacuum or PCV hoses? intake manifold torqued down correctly? intake tube loose on throttle body?
Old Sep 5, 2014 | 03:16 AM
dgford99's Avatar
dgford99
Dr.Dirt
Intake gasket was done by Ford, have checked those, did not think it was these. All other vac lines have been replaced. Rubber ones that is. Have one plastic one running from VMV, and one from EGR. Will check those you suggested and will get back to you. Thank you
Old Sep 5, 2014 | 02:42 PM
Bluegrass 7's Avatar
Bluegrass 7
The codes 171/174 tells you about all you need to know.
The Air Fuel relationship is upset. This causes drivability issues because it's not a normal condition.
There is still an air leak as detected by the OX sensors for both banks as excess air in the exhaust.
A verify of the fuel tables will show this.
It would be nice if mechanics would use there test equipment to look at these things instead of guessing both before and after the work is done.
Good luck..
Old Sep 6, 2014 | 06:24 AM
dgford99's Avatar
dgford99
To bluegrass 7
Good luck..
Been replacing vacuum hoses the last couple of yrs because of lean codes. Something caused the intake gasket to go other than age of vehicle. Did find out that this V6 4.2 is notorious for the gasket to be replaced. Your right that these mechanics need to use these tools to get to the root of the problem, unless it was meant to keep bringing me back so they can have access to my bank account, LOL.
Old Sep 6, 2014 | 06:31 AM
dgford99's Avatar
dgford99
Dr.Dirt
Was able to check PCV, there is vacuum there, haven't checked torque on intake, intake tube is tight, unless its worn, tube going from VMV to intake seems like its collapsing a bit. I don't think it's supposed to b doing that. Acts like there is blockage coming from the rear fuel system. Thank you
RVA
1997 - 2003 F150
Nov 2, 2016 10:57 PM
rhstubby1
1997 - 2003 F150
Jan 8, 2013 05:35 PM
nintey4f150
Aug 1, 2012 10:31 AM
BltFordTough
1983 - 2012 Ranger & B-Series
20
Nov 3, 2005 07:18 PM
miked79928
General Automotive Discussion
Apr 3, 2005 09:31 PM
