Sponsored by: Auxito
starting problems
Old Sep 3, 2014 | 08:40 AM
sparticus220's Avatar
sparticus220
One thing it seems to happen more when hot but it has done it at first start. Also i can try to start it and after maybe 2rotations it has a quick pause that noise then starts turninv over again and starts up
Old Sep 3, 2014 | 09:00 AM
Tedster9's Avatar
Tedster9
Originally Posted by sparticus220
Now im second guessing myself, lol its so hard because i just went out and tried to get it to do it and the truck started every dag on time i tried maybe 30 times and couldnt get it to do it. I dont get it..im so confused
Let's not make any new problems! The starter is designed to run only a split second. They aren't rated for continuous duty put it that way. Same thing with the battery. One thing about electrical connections, there isn't much that looking at them can accomplish. Making sure they aren't loose, that's about it.They can get goofy long before any visible corrosion, though. Oftentimes just breaking them loose and retightening is enough to get you going again, but it pays to take the time to clean them free of paint, grease, etc, down to shiny bare metal.
Be careful working around batteries. Disconnect the negative battery terminal first, and then clean and tighten at the solenoid/starter, engine block, battery posts, etc. this is your plan until you can get a voltmeter on there and see what's what. A voltmeter is one of the most useful tools in the box and will tell you what's going on in seconds, and save you time and money, unless you want to pay somebody else to do it for you.
Old Sep 3, 2014 | 09:01 AM
sparticus220
No the ac isnt on and yes it seems to happen more when its hot but had done it at different times. One thing though i have a coolant leak i believe is coming from the heater core. But is hard to tell because the constant dripping is coming from over the passenger side converter and i cannot locate where its originating from. Could that leak be leaking on top of the solenoid shorting it out?
Old Sep 3, 2014 | 09:07 AM
sparticus220
Thanks tedster im going to put it up on my lift and take it all apaft and do as you suggested and clean everything and put the meter on it. Thanks for all the helpguys. Ill let you know what i come up with
Old Sep 3, 2014 | 09:11 AM
carguy94's Avatar
carguy94
water should not have anything to do with it other than rusting. it sound like a starter issue find a way to check your power at the starter. it is nice to see amperage when looking at starters but voltage will do. you can do a voltage drop on the starter
Old Sep 3, 2014 | 09:21 AM
sparticus220
Will do, as soon as i get home from work im on it. Ill let you know what i come up with. Thanks man.
Old Sep 3, 2014 | 09:34 AM
sparticus220
Hey carguy you know i just saw where you are from..i live in mechanicsville, md.
Old Sep 3, 2014 | 09:39 AM
carguy94's Avatar
carguy94
same here I live on sandgates nice weather for working never seen anyone on this forum from down here.
Old Sep 3, 2014 | 09:41 AM
sparticus220
Dude i live right across the street from sandgates road on mar a lee
Old Sep 3, 2014 | 09:51 AM
carguy94's Avatar
carguy94
you live right near the elementary school heading up the road don't you .
Old Sep 3, 2014 | 09:53 AM
sparticus220
Directly across from oakville elementary...small world
Old Sep 3, 2014 | 09:59 AM
carguy94's Avatar
carguy94
you got that right. don't know if you need it or not but if you need some help I can give you my phone number if you got it under control then that's good to but if you need it let me know.
FordLou
1997 - 2003 F150
Jun 9, 2018 10:37 PM
cajun1965
1997 - 2003 F150
Jun 29, 2012 05:26 PM
efrobert
1983 - 2012 Ranger & B-Series
Dec 19, 2010 02:50 PM
peter p
1997 - 2003 F150
15
Mar 7, 2007 01:03 PM
StrayKatJJL
Electrical Systems/Wiring
Jan 5, 2007 05:30 PM
