Door panels and misc issues
Old Sep 5, 2014 | 07:53 PM
Trackerrrr's Avatar
Trackerrrr
It's also a good time while the driveshaft is out to consider changing the rear seal on the transmission if it's weeping or leaking.
Old Sep 6, 2014 | 11:07 PM
lavatan's Avatar
lavatan
Do you need a press to get the carrier bearing off the driveshaft or will some pressure take it off the shaft?
Old Sep 6, 2014 | 11:10 PM
lavatan's Avatar
lavatan
That's already been done but the cover for the PTO is leaking. I don't think that's the issue. Luckily the carrier bearing is relatively cheap.
Old Sep 6, 2014 | 11:11 PM
lavatan's Avatar
lavatan
I've got a left rear door panel from my '83 that you can have for shipping but you'll have to fix the speaker holes that were hacked into it. I swapped a '92 rear door and the old panel don't fit.
I might take you up on that if I can't fix the existing panels.
Old Sep 22, 2014 | 05:48 PM
Trackerrrr's Avatar
Trackerrrr
PM me if you want it. It's hanging in my garage for now.
Old Sep 22, 2014 | 09:21 PM
Rusty_S's Avatar
Rusty_S
Originally Posted by Gary Lewis
Jim is spot-on as always. But as the vibration is a recent issue I'd bet on a u-joint.
For the door panels, I've never seen one so bad as to have holes all the way through, so they must really be bad. I would go to a salvage and look for some as every panel I've ever seen was better than yours. And I live in an area that gets very high UV.
Thats how mine is on my '82. The driverside door panel the top where you would rest your arm on the window sill, theres about a 2" long hole that is ovaled. The driverside isnt that bad yet. But the door panels on mine will be replaced.
Would like to replace my dash shell as well but I think I will just epoxy the cracks and recolor the dash to match my new dash pad and door panels.
Old Sep 23, 2014 | 11:07 AM
1986F150six's Avatar
1986F150six
Too bad you were not at the OK GTG, last week. Some door panels were available... dusty, but in decent shape.
Old Sep 23, 2014 | 11:11 AM
lavatan's Avatar
lavatan
Well, last week I was in Arkansas riding 300 miles on the Pig Trail.
Were there any there that would be for a rear full door?
Old Sep 23, 2014 | 02:44 PM
1986F150six
None were for the rear doors. Sorry!
Old Sep 27, 2014 | 08:20 PM
carlyoung's Avatar
carlyoung
door panels and misc
I have thought about having someone with a 3-d printer make some door panels. but I need a 3-d scanner and a lot of cash to build a printer big enough for a door panel.
Old Sep 27, 2014 | 08:54 PM
Gary Lewis's Avatar
Gary Lewis
That would be a good use for a 3D printer! But, it sure would take a big one. Some day though.
Old Sep 28, 2014 | 07:45 PM
lavatan's Avatar
lavatan
The 3D printers I've seen are pretty small. You'd have to glue the pieces together like a big jigsaw to get a complete door. Then it really would be a frankentruck.
Old Sep 28, 2014 | 07:58 PM
  #28
carlyoung's Avatar
carlyoung
Be nice when the tech catches up.
Old Sep 28, 2014 | 08:15 PM
  #29
Rusty_S's Avatar
Rusty_S
That is one thing I hope that comes out of 3D printers. Could print new instrument cluster housings for the 1970`s Fords as they are known to fall apart due to their organic construction.
Would also allow us to create plastic pieces that are hard to find, such as dash shells, dash bezels, glovebox doors, kick panels, etc
Old Sep 28, 2014 | 08:51 PM
  #30
Gary Lewis's Avatar
Gary Lewis
They say they are now printing food. Soon metal.
