F150 04 Auto Shift problem
Old Aug 30, 2014 | 03:00 PM
larrywcc's Avatar
larrywcc
I read though many post but have not found anything like the problem I am having and if so I am sorry. Like to figure out something before I take it in
I have an 04 F150 with over 100,000 miles on. Started yesterday and today worse. The fluid is fine. Only issue I am having is around 30 mpg when the transmission (auto) changes gears. The motor rpms will rise but the trans does not shift correctly. Now starting off or on the highway it will down shift everything works but around 30 mph. A few times it will shift without me noticing anything other times it will take a bit to shift still in gear but shifts at higher rpms and rest of the times rmps will jump up and the truck is in neutral if I get go of the gas it will shift. No clunk or shudder
Thanks for any help...
640 CI Aluminum FORD
2009 - 2014 F150
Nov 14, 2011 07:55 PM
mudguy33
2004 - 2008 F150
May 6, 2009 08:06 PM
reel_scream
Oct 18, 2004 08:58 PM
