c6 decoder ring
Old Aug 30, 2014 | 12:17 PM
chaser1602's Avatar
chaser1602
c6 decoder ring
Apparently I cant get the right wording in the search to find c6 build date codes. When was it made
Are they all 66-91 years if I am looking for a manual ?
Old Aug 30, 2014 | 01:24 PM
mikeb's66's Avatar
mikeb's66
Are you referring to your transmission?
Old Aug 30, 2014 | 02:00 PM
chaser1602's Avatar
chaser1602
Yes. Its not an original. Its going to replace the c o m. Its a piece I picked up from a trans shop that I used to do bizzniz with in ga. Supposed to be a rebuilt but I want to go thru it and take a look at it b 4 I install it. I need to find a manual for it.
Just wondering if c6's built for an fe were only made from 66-91?. Then I wouldn't really need a date code, but it would be nice to know when it was made. That's all
Old Aug 30, 2014 | 02:08 PM
mikeb's66's Avatar
mikeb's66
C6's internally are all pretty much the same. As long as you have the correct bell housing pattern you should be good to go. You can find a manual online, just google atsg. They make really good manuals for automatics. Usually have step by step to tear down and rebuild.
Old Aug 30, 2014 | 02:10 PM
chaser1602's Avatar
chaser1602
I went to atsg for the book. All they have is a dvd??? I want a BOOK
Old Aug 30, 2014 | 02:12 PM
mikeb's66's Avatar
mikeb's66
Yes, they stopped printing books for older transmissions. I work at a transmission parts supply house. I can check on Tuesday to see if we still have the paper version.
Old Aug 30, 2014 | 02:15 PM
chaser1602's Avatar
chaser1602
I would really like that if it isn't to much trouble
Old Aug 30, 2014 | 02:20 PM
mikeb's66's Avatar
mikeb's66
No problem. Does your C6 have the truck style bolt on yoke? If you can get the casting number on the side of the case, I can at least give you a range of what years yours covered.
Old Aug 30, 2014 | 02:43 PM
chaser1602's Avatar
chaser1602
The best I can tell it is D6 tp 7006 ata
There is a 3 73 cast into it below those numbers
Thanks for reminding me I need to find a yoke. Would you have a line on those also?
Old Aug 30, 2014 | 02:49 PM
mikeb's66's Avatar
mikeb's66
The "D6" says its a '76 and later transmission. What size motor are you wanting to bolt this up to? I will check on the yoke as well. I know we have the correct tail housing cuz I just put one back in stock yesterday.
Old Aug 30, 2014 | 02:58 PM
chaser1602's Avatar
chaser1602
The idea I have now is for a 4-500 hp motor. I have no idea what is in there now. What is in there now is going to be a factor in what I build. 428 sounds nice. More than likely only a 390 though.
Old Aug 30, 2014 | 03:03 PM
mikeb's66's Avatar
mikeb's66
Does your C6 look like this one? This would fit a 352-360-390 motor. I think you might have a 300-302-351 type case, but I could be wrong. Wouldn't be the first or last time.
Old Aug 30, 2014 | 03:11 PM
chaser1602's Avatar
chaser1602
I know what your talking about. I have an fe case
4x41977
Nov 15, 2012 05:55 AM
68murc
Apr 5, 2007 09:20 PM
tastyklair
Dec 10, 2004 01:48 AM
daveengelson
Sep 17, 2003 04:06 PM
AZ4x4f150
Jan 26, 2002 11:41 AM
