I was wondering what kind of 12v under hood LED lighting options have been installed. I was thinking of using a continuous LED light strip routed zig zag under the hood, or perhaps two or more strips, rather than just a replacement LED bulb.
I was trying to figure out why you need so much light for under the hood? Show truck?
I hope I don't need shop lights with this one -- I certainly didn't with the 2011 I had.
The light that came with mine is adequate for the few things I would and could do under the hood at night. Considering I survived 4 years with none in my 2011...
Although I have yet to have any issues with my 2011, I figure that the odds may catch up with me like it did with my cousin traveling to Alberta. There's nothing like a road repair with not enough light that can ruin a trip, especially in bad weather.
Just thinking ahead.
I ordered some waterproof LED lights that I will be pting under the hood and another set in the bed.
I'll let you all know how it turns out. I will be using a magnetic switch for the bed lights. The lights will illuminate when I open the rear glass door.
Despite the detractors above, I've had many occasions with past vehicles of my own and others when i've needed auxiliary lighting to work on a vehicle at inopportune moments.
Overall I'm pleased with the result of this project as well as the installation of an LED light string on the ceiling of my camper shell ( https://www.ford-trucks.com/forums/1...l#post14716707 ) although the installation looks a little unfinished under the hood.
I ended up dovetail tapping into the under hood tilt switch to activate the lights when the hood is opened. The 15' LED light string is held in place with Magdaddy magnets acquired from Amazon.
I ended up using both the rectangular shaped magnets and the round magnets as they have different strengths at different locations. The round magnets seemed to swivel the plastic loop used to thread the zip tie through for mounting the lights. I used the round magnets for the corners and the rectangular magnets for the straight sections of the light string.
I guess for the same reason I carry a spare tire, a jack, tools, have four wheel drive and wear my seat belt. Just in case something happens...
Then let me add that some LED's under the truck next to the exhaust would be good idea. And add a spare EGT sensor to the list. Chances are you will need one sooner or later.
I also have a rope light to maneuver in recesses where a flashlight can't reach.
You'd be surprised how many times I've pulled up and used my floor jack and four way lug wrench to change a tire for someone who's fiddling with a bottle jack. I have a reputation with my family to be somewhat of a mobile pit crew. It's always nice to have the right tool for the job at the most inopportune moment.
Speaking of which, excuse me while I run to Costco to get another floor jack...
