Modular V10 (6.8l)
Got A Little Engine Clatter
Old Sep 12, 2014 | 05:19 PM
  #31
pappy19's Avatar
pappy19
Yeah, it hurts, but I figure in the long run, it's the best deal for me. I travel alot and if something goes south again, it's a Ford warranty, so I just go into a Ford dealer. I could have found a cheaper rebuild and had a shade tree do the work, but if it ever screwed up, I'd be out more plus the hassle. If the truck doesn't stay sound, I'll just trade it off for a new 6.2, but I really love the V-10, so not inclined to do that now.
Old Sep 15, 2014 | 09:33 AM
  #32
pappy19's Avatar
pappy19
Picked up my F-250 with the new engine. Definately more quiet and seems to have at least the same poop as it did before. All the wires must have been put back ok, seems everything is working. I will report later as I have a 300 mile trip to take today for a shake down.
Old Sep 18, 2014 | 09:29 AM
  #33
Jeffro70's Avatar
Jeffro70
WOW. sorry about the 6.8 death in the family, but IMHO, i would suggest the recommended motorcraft oil and filter, and after a good break-in period, substitute 1qt of Lucas full synthetic at every oil/filter change. I've gotton 203000 miles out of mine so far and still pull a 37' 11500+/- lb 5th wheel at sometimes high rpm. Good luck on the reman!
Old Sep 18, 2014 | 09:39 AM
  #34
pappy19's Avatar
pappy19
So I should tell the Ford dealer to only put in 6 qts of Motorcraft oil so I can dump in a qt of Lucas synthetic?
Old Sep 18, 2014 | 10:39 AM
  #35
Jeffro70's Avatar
Jeffro70
I would, after the break-in period. I have always used it, and my previous 88 f-250 with 7.3 IH, used 2qts (regular Lucus) with every oil change, it had 425000+ miles on it when i sold it! it was still running strong.....never heard a bad rap on Lucas products from anyone yet.
Old Sep 18, 2014 | 10:57 AM
  #36
Jeffro70's Avatar
Jeffro70
one more thing, make sure they wont try to feed you some crap about voiding the warranty! I dont think it will, at least thats what the bottle says. I talked to my service manager at the Ford dealer and he said I could my on oil changes as long as i recorded it and used Motorcraft oil/filter, but i didnt ask about Lucas stuff. Of course, i was only courious, i havent had a warranty since i bought a new escort in 1994! LOL
Old Sep 18, 2014 | 04:13 PM
  #37
pappy19's Avatar
pappy19
Actually, I have a Fumoto oil lever drain plug instead of a regular screw on drain plug, so I can dump a quart easy and then add the Lucas. I just hate to waste a quart of perfectly good oil.
Old Sep 18, 2014 | 04:31 PM
  #38
Jeffro70's Avatar
Jeffro70
Good idea! Where do you get one of those drain things?
Old Sep 18, 2014 | 04:37 PM
  #39
pappy19's Avatar
pappy19
Here you go-
Fumoto Valve | Qwik Valve™
Old Sep 18, 2014 | 05:22 PM
  #40
Jeffro70's Avatar
Jeffro70
Thanks!
Old Sep 18, 2014 | 07:28 PM
  #41
UNTAMND's Avatar
UNTAMND
Drain it back into a jug.... How else are you going to know how much a quart is. LoL
If it's clean oil, use it in something else or use it as a makeup quart later.
Patnoel
Oil & Lubrication
36
Aug 26, 2016 02:23 AM
Avbird
Apr 22, 2009 03:08 PM
power bus
16
Oct 7, 2007 08:20 PM
cooky
Oil & Lubrication
Nov 17, 2006 04:50 PM
HDMustF250
Feb 13, 2004 12:42 PM
