Sponsored by: Auxito
Creaking while turning
Old Aug 28, 2014 | 04:13 AM
greatswisscheese's Avatar
greatswisscheese
Hello all, 2001 F 150 5.4 V8 4WD. I have a weird creaking sound coming from the front end, sounds like the passenger side, whenever I turn right at any speed. Anyone else ever have this problem or know what it is?
Old Aug 28, 2014 | 09:03 AM
Bluegrass 7's Avatar
Bluegrass 7
You have to inspect the area for the issue.
It could be anything.
Good luck.
Old Aug 28, 2014 | 06:40 PM
Dr. Dirt's Avatar
Dr. Dirt
does it do it when you're sitting still?
Old Aug 28, 2014 | 06:43 PM
JWC 3's Avatar
JWC 3
Dry ball joints ....
Old Aug 28, 2014 | 09:36 PM
steve(ill)'s Avatar
steve(ill)
or bad wheel bearing... Need to put a jack under the a-frame, get the tire and inch off the ground and start checking - wiggle- push - shove and see what is moving.
Old Aug 28, 2014 | 11:26 PM
Dr. Dirt's Avatar
Dr. Dirt
as a matter of fact I had one about 10 months ago it would only make noise when turning to the right forward or backwards. this was an F250 though
Old Sep 22, 2014 | 11:41 AM
bugaha's Avatar
bugaha
could be a loose stabilizer bar causing the noise. Jack it up and tighten and no more noise.
BigDaddyAnt
Dec 27, 2014 09:48 AM
2905kyle
Aug 20, 2010 12:46 PM
Midnightride42
1997 - 2003 F150
Mar 12, 2009 10:35 AM
shurbs2004
Oct 29, 2008 11:01 AM
RLB112
May 27, 2007 06:33 AM
