Rust blisters
Old Jul 13, 2003 | 09:34 AM
Lobstah's Avatar
Lobstah
Rust blisters
I also posted a few pics of the rust blisters on the old gal. Should I sand 'em down and prime them, or just replace the doors and bed?
Lobstah
Old Jul 13, 2003 | 10:34 AM
Stingray42's Avatar
Stingray42
Rust blisters
fix em
Old Jul 13, 2003 | 11:22 AM
rander101's Avatar
rander101
Rust blisters
That is a strong looking truck.
You can fix the rust spots if they haven't rusted through. The trick is to do it so they won't come back. You have to kill all of the rust underneath the paint. Sand the spots down to bare metal out maybe a half inch or so beyond the rust. Then use a rust converted or POR-15 to cover the entire area. When that dries sand just a little more with something very fine like 400 paper, tack if off good then cover it with a good primer and finish with the top coat feathered in carefully. That should keep the rust from recurring. While you're at it be sure all the drain holes in the panels are open so any water that gets inside the door or fender panels can drain out and the inside can dry out.
Hope this is some help.
RussA
Lobstah
Jul 21, 2003 12:53 PM
Lobstah
Jul 20, 2003 03:05 PM
Lobstah
22
Jul 17, 2003 10:44 PM
Lobstah
Jul 10, 2003 02:14 PM
Lobstah
Jul 1, 2003 11:32 AM
