R12 or R134a?
Old Jul 16, 2003 | 03:06 PM
Lobstah's Avatar
Lobstah
R12 or R134a?
Well...I stopped by the local Ford dealer, donated $30.27 to the parts counter, and came away with a new "cycling switch". Got home, grabbed a 5/8" wrench, spun the old one off, stuck the new one one, and PRESTO...cold air blowing in the cab
Thanks a ton to everyone here... I'm SURE that saved me some cash. Now if I can just convince the wiff that I saved enough doing that to buy a nice, new, shiny diamond plate push bumper...hehehe
Lobstah
Old Jul 16, 2003 | 10:46 PM
galaxie223's Avatar
galaxie223
R12 or R134a?
did you lose any freon when you took off the cycling switch???
Old Jul 17, 2003 | 05:07 AM
Lobstah's Avatar
Lobstah
R12 or R134a?
No...it "hissed" for less than a second, just releasing the pressure within the switch itself.
Lobstah
Old Jul 17, 2003 | 01:50 PM
nzabka's Avatar
nzabka
R12 or R134a?
Out of curiousity, where is the "cycling switch" located?
Old Jul 17, 2003 | 02:03 PM
Lobstah's Avatar
Lobstah
R12 or R134a?
If you're facing the radiator, the compressor is to the right, and the dryer is over on the left. It's a black can about the size of a large can of B&M Baked Beans. The cycling/pressure switch is on the left side, with a plug that has two wires connected to it.
Lobstah
Old Jul 17, 2003 | 02:15 PM
nzabka's Avatar
nzabka
R12 or R134a?
mmmm.... baked beans.
I have a similar problem on mine.
Old Jul 17, 2003 | 04:25 PM
Lobstah's Avatar
Lobstah
R12 or R134a?
I followed Jerry's article that was referenced earlier here, I think.
Anyway, with the AC on in the cab, check to see if the compressor is running. You can tell it's running if the center is spinning. If not, pull the plug on the dryer and jumper between the contacts on the plug, NOT on the switch, but on the plug with the wires on it. If that starts the compressor, either the switch is bad, or you have low refridgerant.
Good luck,
Lobstah
Old Jul 17, 2003 | 10:44 PM
steve83's Avatar
steve83
R12 or R134a?
The low-pressure switch is called the "clutch cycling pressure switch".
Darthange
Jun 24, 2005 03:39 PM
Lobstah
Jul 21, 2003 12:53 PM
Lobstah
Jul 20, 2003 03:05 PM
Lobstah
Jul 13, 2003 11:22 AM
Lobstah
Jul 1, 2003 11:32 AM
